midlevel pc build, need help (im dumb)
I havent thought about computers in the three years since I built my last one, but I just got some money and sure. Really dont want any mistakes like my ram not fitting into the motherslot. Heres what a day of holding off pulling the trigger has gotten me:
SILVERSTONE Sugo SG01B-F Black MicroATX Desktop SFF Computer Case
http://www.newegg.com/Product/Product.aspx?Item=N82E16811163116
GIGABYTE GA-G33M-S2L LGA 775 Intel G33 Micro ATX Intel Motherboard
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128085
G.SKILL 4GB (2 x 2GB) 240-Pin DDR2 SDRAM DDR2 800 (PC2 6400) Memory
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231122
Intel Quad Q6600 Kentsfield 2.4GHz 2 x 4MB L2 Cache LGA 775 Quad-Core Processor
http://www.newegg.com/Product/Product.aspx?Item=N82E16819115017
CORSAIR CMPSU-450VX 450W ATX12V V2.2 Power Supply
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139003
PNY XLR8 VCG98GTXXPB GeForce 9800 GTX(G92) 512MB 256-bit GDDR3
http://www.newegg.com/Product/Product.aspx?Item=N82E16814133219
In my crappy googling, I cant really see any great benefit to the G35 or P35 or any of those other northbridges because Im not using onboard graphics. Hope I didn't screw that one up.
Also Ive been reading that the 4850 is better than a 9800GTX, if thats so I will definitely return it. Cant seem to find good benchmarks anywhere. Thanks a ton anyone who replies.
*edit*
thanks alot for the replies, I wont be stressing out while I wait for the better card to arrive.
Funny I havent had an ATI card since a 9700 pro. :eek:
The 4850 is definitely better than the 9800GTX. If you're looking for a good review, check out the [H] evaluation :). The rest looks pretty good.
Considering you can get the Gigabyte GA-EP35-DS3L for even less than the G33 board you selected, I'd get it instead.
It won't fit inside his case. He's going for a SFF setup, not a desktop.
Anyway, with the exception of the video card, your build looks fine to me. Definitely get the HD4850 if you can.
