I'm retiring a 2006 Mac Pro (dual xeon 5150) that's gone through about 4 video card upgrades (currently have a HD5770) and is currently rather CPU bound. All my day to day work has long since moved to an i7 Macbook Pro, but I've still been gaming on the MP. Needless to say it's time for an upgrade and I'm going back to a custom build for gaming.
One thing - my last home build (an Athalon 64) ended up being very loud (which is what I get for putting a cooler called a "Vornado" in it). The Mac Pro is pretty quiet, even at load. I'd like to keep the temps and noise as low as possible while sticking with stock parts.
1) What will you be doing with this PC?
Hello Kitty Island Adventure.
I'm not huge info multiplayer FPS gaming (especially multiplayer) so I don't require astronomical framerates. Diablo 3, SC2, MMOs (Star Wars currently), CivV, single player FPS. I'd like to be able to run those at high quality on a 27"
I suppose it's not out of the question that I'd do some fairly heavy photo processing at some point (Lightroom 4, Camera is 18MP, I shoot RAW) but I tend to do that stuff on my Mac.
Ballpark $1200. That's not a firm number though.
SF Bay Area
4) What exact parts do you need for that budget?
CPU, GPU, RAM, MB, Case/Fans/PSU
- KB (Apple USB), Mouse (Logitech Laser something or other)
- HDD: I have a 1TB Caviar Black I'll be putting in there. I have a 120 gig Vertex 3 in my macbook pro that I'm going to swap out for a 240, probably in a few months. I'll move the 120 to the gaming rig when I do.
- Optical: Do people use these anymore? Anyways, I have an external. I suppose I could move the existing DVD burner out of my mac but it's IDE.
- GPU: I am considering keeping the 5770 for a month or two while prices stabilize and my wallet recovers and then getting a GTX680. But based on the 670 reviews it doesn't seem worth it. Budget does include the GPU though
6) Will you be overclocking?
Probably not at this point.
Apple Cinema LED 27" 2650x1600 - NOT the thunderbolt version - Any issues w/ using this monitor on a homebuilt PC? I use it with my work HP elitebook over displayport w/o issues.
Flexible. Within a month, probably.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video (as a backup or main GPU)? UEFI? etc.
- SLI, USB3, SATA 6, optical audio (w/ 'advanced' codec passthrough) are more or less must haves.
- eSATA, F800 would be great. Display port for the onboard video would be great as well, as would audio over hdmi if I move this to a HTPC build at some point.
- I could see myself possibly going SLI at some point to pickup framerates on the 27"
- Easy OCing. If I go that route I'd like to have a decent BIOS to work with
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? Is it 32bit or 64bit?
Not sure; Roommate might have an extra license on his OEM 3 pack. Will go OEM Home Premium 64 otherwise. I was thinking about Win 8 Preview - will that work for this? (I'm a UI designer and would like to play w/ Metro)
When in doubt, I'd prefer to buy from amazon (prime shipping + no tax)
$190 CPU - 3570K from Microcenter. Am willing to entertain suggestions to go with the 3770 but the microcenter 3570 v. the newegg 3770 seems like a no brainer. Stock cooler is ok? The computer will be in a loft where it can hit 80 degrees, but anything above that I turn on the a/c. I'm willing to swap in a cooler at a later point if i decide to go with moderate OCing. Noise is a bigger concern though, my last non-retail cooler was VERY loud.
$115 MB - GA-Z77X-UD3H (microcenter bundle)
$399 GPU - EVGA GTX 670. Had an EVGA Geforce 6800GT way back on my last custom build and thought it was a great card w/ good support. (Looks like I missed the newegg in stock window, but I'm assuming these won't be too hard to snag if I'm signed up for notifications)
~$50 RAM - 2x4GB G.SKILL
$140 - PSU - SeaSonic X Series X650 Gold - Again, attempting to keep things a bit quiet. Overkill? I love the fully modular design.
$135 Update: Corsair 550D -- of all the suggestions below this seems to be the best alternative. The silverstones seem to be a bit pricey and I prefer the look of the corsair to the Fractal.
Alternate: $120 Case - Antec P280 - Seems well reviewed, recommended from the silent PC folks. Again, open to suggestions. Smaller is better than bigger (but I don't want airflow issues) and I don't tend to like elaborate-looking cases. *** I'll check out some of the corsair cases recommended below
Of all the components I'm most open to suggestions on the motherboard. None of them seem to be the right mix of value/features for me so I feel like I'm either overbuying or compromising.
Have at it and thanks in advance!
$1029 pretax/no OS
[Edit 1: Updated motherboard + RAM]
[Edit 2: Looking at the Corsair case instead]
SF Bay Area
$1029 pretax/no OS
