Hi,
anyone found and has experience with using a microSD model card capable of wirting 20MB/s 24/7 5yrs?
thats what I was afraid. the problem is we need to build a small server that has only two 3,5" slots for HDDs and they must be filled with 6 TB drives. I guess similiar thing to the microSD situation will be with USB sticks..
does it have a external USB 3 port? if so a small SSD in an enclosure will work.
The idea behind those in servers these days is to be cheap storage, easily replaceable for headless host OS such as ESXi or Hyper-V nano where the VMs are stored on much more expensive devices and arrays. These OS versions don't undergo 24/7 writing so I'm wondering what application you are curious about that does![]()
Which is why I explicitly mentioned SD for just the OS of the hosts that utilize the faster storage for VMs that are running the production servers. The host OS (to clarify: bare metal) does not need to be blazing fast at all so it makes sense not to waste resources on it.Not 100% true, people are / should be moving away from expensive SANS in many scenerarios short of large scale enterprise, and using local storage which is cheaper and faster in a set up such as a VSAN or starwind for example.
