Microphone Volume Too Low
Klynt
I just bought a new headset from Logitech and despite my best efforts I can't seem to get the volume up high enough for people to hear me. This seems like a simple problem as if I take the head set off and talk directly into the mic it comes out as clear as I need it. I was wondering if there were some kind of utility/tool that would allow me to adjust the volume of my mic higher than what windows initially allows. My sound card and headset aren't the greatest but it's the not quality that is giving me the trouble, it's just the volume. Incidentally I'm using an onboard Soundblaster Live! 24 bit soundcard along with god I don't even know 15 dollar Logitech headset. Thanks for any help...
Sincerely,
I still can't hear you
There's a checkbox for +20db boost under "advanced" on the slider for the mic in my mixer. That might be sound-card specific, however
Yeah, I looked at a post that said to do that but there doesn't seem to be anything there for me =/
have you tried updating the drivers? Are you using the built in drivers included w/ XP?
