The case is standard ATX, but it has a MicroATX PSU, specs which are a little too low for my liking (300Watt):
http://www.alienware.com/Configurat...Page.aspx?CatId=1000&ItemId=12161&ItemIdList=
And a shot of the back of the case:
http://www.alienware.com/product_de....aspx?SysCode=PC-DHS5&SubCode=SKU-DEFAULT#sub
My question is: which is the best Micro-ATX PSU that will fit in this case (cost is not an issue)? I'm going to put at least a 6800 Ultra in it, probably a G70 more likely, so that will probably blow it up. Most of you recommend Fortron, but the highest one is only 180Watt... and the fan on top bothers me, because I don't think it's going to fit inside the case:
http://www.newegg.com/Product/Product.asp?Item=N82E16817104981
There's another PSU with much higher rating (450Watt), but it's made by "Athena"? Is that a reliable brand?
http://www.newegg.com/Product/Product.asp?Item=N82E16817104124
