Not really into promoting facebook liking stuff, but this is a pretty good deal if you have a Micro Center nearby.
http://www.facebook.com/MicroCenter?sk=app_263996086966257
good deal if you just need a solid quad core and don't plan on doing any overclocking.
Pretty sure you can do some mild overclocking and hit ~4.0 with a P67/Z68 board![]()
No, this processor does not have an unlocked multi. The best you could do is set it at it's max Turbo setting (3.4 GHz).
Umm no u can't. CPU is locked. Could probably squeeze a couple hundred extra MHz by upping the BCLK a few MHz but that's it.
DOH! Expires 1/10/12 summabitches! And its not like I can do in store pick up and have them charge me now then pick it up when I get back on!
Double DOH! I apparently did open the box, so they probably wouldn't accept a return anyways.
I must be thinking of the non K 2500, but I swear someone was able to get to 4.0 even with just the few MHz changes.
I believe coupon expires 7 days from when you signup, so see if the deals still on in two weeks. I thought Micro Center took back just about anything.
um, you can overclock 4 bins(400mhz) for non-k cpus on p67/z68
Ummm I'm not trying to disagree, but please explain these. Are you saying the following are only hitting those max clocks with a single core via turbo?
http://valid.canardpc.com/show_oc.php?id=1765795
http://valid.canardpc.com/show_oc.php?id=1801462
http://valid.canardpc.com/show_oc.php?id=1903929
http://s1.postimage.org/58j76meax/4128_8.jpg
http://valid.canardpc.com/cache/screenshot/1806531.png
All form this thread - http://www.overclock.net/t/1006651/i5-2500-non-k-overclocking
I swapped my FX6100 with the Asus Crosshair Formula board for this deal. They will exchange only, not return for refund.
And yes you can have them charge your card for in-store pickup. I did that on the 1055T deal when they had it going on.
Hmm anybody have some insight on this vs an i3 2125 for an HTPC?
would it be worth it to pick this up to replace an i3 2120? not sure if I should just go for the 2500k if i'm gonna make the hour drive to MC.
i have an msi p67-gd55 and a spire thermax eclipse II i had laying around. And I would only really be using it for gaming at 1920x1080 on a westy 37w3. i have 2 6870s for crossfire so I don't know if the i3 is holding them back or not. i would overclock if i could.
I wouldn't overclock any non K edition. It's not worth the risk and strain put on the BCLK clocking
Is the 10th the last day or is it over on the 10th?
