micro atx PSU and HD4850
zalazin
I decided I would try my New HD4850 in my lowend rig. Before a having all the hassle to remove my 8800GT. I Spent three hours getting the physx geforce beta to work today,also only other machine I have with Vista.
Specs are Gigabyte GA-945GCM-S2C, Celeron E1200 Dual core, 2Gigs 0f DDR2800
Samsung DVD burner and Hopefully HD4850. WinXP/VISTA Dual Boot.
WD320 HD
Only Question Is power
Athena Power MP4ATX400 SFX MicroATX PSU Specs ARE:
+3.3V@12A,+5V@19A,+12V@20A,-12V@0.8A,+5VSB@2.5A
Only one 12 V rail and one PCI-E connector. I have used this PSU in the same case with a 2.80 Northwood P4 and 7800GS AGP 2gig Via MOBO System in the past with no problem. Am I pushing My luck here?
From the limited information I can find so far about Athena, the quality of Athena PSUs are very very questionable. So it may not be capable of actually providing 20A on the +12V rail. I say you're pushing your luck. 20A, if that Athena PSU could provide that much power, is cutting it close IMO.
It is actually running 3dvantage without a problem, but I don't trust it to hold up.Only problem hard to find a high power microatx PSU.
No, the only problem is finding a good mATX PSU. The selection of mATX PSUs isn't that great and their quality is not good enough for a gaming rig. Out of all the mATX PSUs on newegg, I'd trust the ones made by FSP. Even then I'm still a bit unsure about that.
