Micro ATX mobo in ATX case?
Yes. If you look at pictures of the interior of the case, there should be an extra set of screw spots for standoffs about midway up the mobo area.
There are only a few cases nowadays that don't have mATX support that i've seen...
I'd like to ask tho...why not get a mATX case?
tiger direct had a great deal on the MicroFly case for 50$ the other day...
I'm not actually building a new PC right now. I'm just replacing a mobo and processor. I've already got a case or else I probably would go with one of the small ones. Those seem like they would be pretty convenient.
As long as it's not something like a Dell motherboard you should be ok. Some of the OEM's use proprietary boards and mounting. Not saying you are, but just a warning since I don't know where you're getting your board from.
Only if it is a super old Dell case could you get away with it. My ancient Dell XPS P3 case has standard mounting, and they were even nice enough to leave mounting screw thingies in every hole in the case....hehe
