Micro ATX MB for file server.
Justintoxicated
I just picked up a P180 Mini and it can fit quite a few hard drives into it and I plan to fill it with 2TB drives once released...
I need a micro ATX motherboard that has alot of Sata Ports and will be stable.
Gigabit Lan is a +
I have DDR Ram and a 1700+ Laying around which would be nice to use as well but not necessary.
My plan is to setup an Open Filer box with Flex-Raid for archiving purposes. I'd appreciate suggestions. AMD or Intel is fine but cost is an ISSUE. I want to keep this as cheap as possible but I'm willing tp pay a little more for a board with raid and extra sata ports.
If you're going to reuse that AMD CPU, you're probably going to have to get some PCI SATA cards. They aren't too expensive from Newegg. I have an old Compaq Presario desktop with a 1700+. No SATA onboard, but it had 3 PCI slots, so I had to go with a controller card to get SATA. Not sure if you're going to find a board though in mATX unless you get one out of an old OEM build. Might have to go with a new setup altogether. Definitely not going to get GbE without a newer setup or via PCI card.
I never reallyed looked into matx until I bought this crappy Antec micro P180 case, I see some newer boards that meet both of these for about the same price, but then I need to spend a little extra for a newer CPU...I'll have to think it over I guess.
i love the antec mini p180 case, i have my WHS in it right now... its cool, quite and looks nice... with lots of expandability.
As for a matx board, i have a foxconn 780g chipset motherboard, 6 onboard sata port for $66
pair that with the cheapest AM2 CPU you can get (X2 for anything other than file serving)
and 2gb for RAM for $25
and you have a nice little box.
Honestly, that's probably what I would do. New CPU/Motherboard/RAM for just a little over $100 if you shop around and look for deals and rebates.
Thanks guys I was looking at these two motherboards.
For True, Asus > Fox Conn, however I'mm not thrilled about buying older technology for more money unless there is a good reason for it.
http://www.newegg.com/Product/Produ...N82E16813131237&Description=micro ATX&bop=And
Can't decide which one (help appreciated). I'm prefering this over the AMD solution just because, well I don't want nvidia chipset.
I picked up 4GB PC6400 OCZ for $10 after rebate so thats done :)
edit: Just realized that this does not use an nvidia chipset so I may use this option :)
http://www.newegg.com/Product/Product.aspx?Item=N82E16813186141&Tpk=foxconn 780g
Here is a cheap CPU, and Motherboard combo http://3btech.net/alasp5seinpe.html
Only issue is not as many SATA ports (card will be needed) and less warranty, but certainly is an option as it is the cheapest solution yet :) but I kinda feel like I'd be better off with teh AM2 or intel just cause I'm buying all new stuff anyways and the above boards could easily be converted into a Media center PC at some point if I decide to go a different route for storage in the future.
I kind of like that Foxconn board above. That and a cheap E2XXX series or even a dual core Celeron would probably be a nice file server with RAID 5.
I was thinking to use open filer since most of the data will be for archiving. Just not sure if I'm brave enough for that one yet :p
The foxconn board has great reviews but the quality looks far below Asus, from the Capacitors to the cooling (on the AMD version, not so much on the Intel Version). But that's not for certain as looks can be deceiving... I'm having allot of trouble deciding, AMD looks to be cheaper but I'm afraid of the processor getting too hot since I want to keep the noise levels down in this case, and there are no case fans for the hard drives (stupid design of P180 mini)
Case will be antec P180 mini which will mostly rely o the 200mm fan for cooling.
I risked it going for the foxconn G45 board, the sale on the asus ended so that made my final decision easier. For the Price of the Asus I would be wishing I had gone for the DFI, but the DFI did not have onboard video etc etc and the price keeps climbing....
All I really need to run this stuff is a Celeron 300a with 512Mb of ram lol...
But its all good, I will just need to wait for a used C2D now to finish the build. Hoping for an e5200. Or maybe I should upgrade my main rig and toss the old Q9450 in the archiving box...I know I said file server but it really will only be feeding 1 or 2 PC's max, both wireless and through my Gigabit Lan thanks to my hacked buffalotech router working as a repeater-bridge :)
Since I opted for the faster system I'm considering also using this for an http server development environment.
Thanks for everyones help!
Sounds like a nice little project. Hope it all works out for you. Merry Christmas ;).
