Meshify Mini C microatx king?
OFaceSIG
Is the meshify mini C the best microATX case out there? This is going to sound petty but I like everything but the odd blue power led/hdd led combo light on the front.
I’m waiting on the o11-d mini snow edition, only drawback is the sfx psu requirement if you’re going for a beefy build.
The O11 Mini is probably the most versatile case out there without being super large. My build is in it now. Just put it together this weekend & have it mostly done. Waiting on Unifan's to get here before I complete it. The motherboard tray's modularity is what really makes it. Its not a hugely oversized case & moving the motherboard tray to wherever works best for you & the cooling you want is just phenomenal. Mine is using an itx board in the 5 slot config with dual 360 rad's (or at least it will be when I put the bottom rad back in, had a leak during initial testing that took me a bit to figure out).
