memory won't oc at all
bmx
I can't seem to OC my memory even 1 mhz, and if i try the computer just wont boot. I have Corsair twin2x2048-6400 memory and a ds3 mobo. right now i have 4-4-4-12 timings at 800mhz stable and +.3v, but i try to go over 400 mhz fsb and the computer just wont boot. I loosened the timings to 5-5-5-15, and upped the mem voltage to +.5 and I still can't get over 400 mhz fsb. It seems as if the memory just wont work over its stock 800 mhz. any ideas on what i can do? I have the F9 bios for the ds3 as well.
TOO MUCH !!!!! as strange as it sounds too much memory voltage can limit overclock ability of some memory chips.
Have you tried the looser timings at like +.35 +.375?
I think I have the same stuff and see my sig. I would not go above +.4 (2.2 Vmem) on that memory imo.
( I am sure a bunch of people have put 120 VAC to their memory modules and ripped holes in the space-time fabric with the memory overclock, the above is just my opinion based on safe long term operating conditions. Its your stuff, do what you want. )
And it seems silly but are you dead certain you have them in the correct memory slots ?
Also try setting the timings to SPD and see what happens.
hoppeler- i know where it is and all, there just isnt a setting so the fsb is higher then the mem speed, its either 1:1 or higher.
billparish- yes i've tried just about every voltage setting up to +.5v and no go. and ive tried lossening the timings to 6-6-6-18 with all the voltage settings and still nothing. i normally dont keep the voltage above +.3 but i tried to push it up to see if it helped at all. and yea the mem is in slots 1 and 3, reseated them and all. i dont think theres a setting for spd in the ds3 bios
