Hi,
I have a 6300 on which I'm running two instances of F@H as services. Both seem to be running correctly (though I honestly wouldn't know how to check)
In the settings for each I've allocated up 500mb of ram to do with as they please. I only have 1gb at the moment so that may be a bit much to allocate though.
My worry is that one of the instances never uses more than 4mb of memory, while the other can be using anywhere between 100 and 500mb.
Does that seem normal? I figured that two separate instances with separate machine ids and in separate folders should both act identically.
Thanks
knz
Thanks
knz
