Memory upgrade ?
jime
I have an Abit IP35-E(CPU P4 670@3.8ghz) with 3gb of DDR2-800 running at 5-5-5-18 and I'm thinking of upping it to 4gb of Kingston Hyper-X DDR2-1066 running at 5-5-5-15. I run Windows XP-Pro 32bit so I know I won't see all 4gb's,but it's 2x2 and currently my 3gb is 2x1 / 2x 512. My understanding is it runs better(smoother) with the 2x2 set-up.
My question(s) are will they work on this board ? and maybe overclock them ? or
Should I just get the 2x2 DDR2-800 running at 4-4-4-12 ?
They're both around the same price but which would run better? Is there that much difference between 4-4-4-12 and 5-5-5-15 ?
Thanks for any assistance.
jime
Get the DDR2-800, unless the 1066 is about the same price. you really won´t see much of a difference between the two, plus the 800 you can still OC your cpu higher than you probably will ever want to with the 800.
Thanks for the reply. I think I'll get the 1066 for when I upgrade the CPU and their OC potential.
By your reply, I gather the 1066 will work on this MB ? It's rated for 800 but is a great OCer so I'm thinking it's possible. Yes ?
Again thank you for the reply.
I just looked up the specs and it doen´t support 1066. Maybe somebody that has this MB can say if they have tried it or not. You might want to get some cheap 800 now and later upgrade the CPU, RAM and MB. Abit no longer exists so there is no support, or BIOS revisions to support newer parts.
I have the IP35 PRO which also was never "listed" as supporting DDR2-1066 but I can tell you it runs that and beyond without any issues. I have 4x1GB of Ballistix 1066 ram in it now.
Are you having problems with your current memory config? Personally, I wouldn't touch it. You're changing for 200mb extra. I don't know what you mean by "smooth." I don't think you'd see any difference at all.
Thanks for the replies guys. Maybe I chose the wrong word when I said smooth,and you'd probably only see the difference in tests. I'm also looking to upgrade not only my CPU but also my OS to XP64,which will definitely see all 4 gigs. I believe that the 1066 is better for overclocking,which is something else I plan on doing in the future just for personal knowledge. But thanks for the advice.
I was just curious as to whether or not the 1066 would even work on my MB.
