GreatestOne
- May 15, 2005
Memory Upgrade Causes PC/CPU Slowdown/Higher Usage
_________________________________________
Not going to details but I finally upgraded my
DDR3-1333 PC3-10666 4X4GB (A-Tech , had great ratings)
to
DDR3L-1600 PC3-12800 4X8GB (G-Skill Sniper)
I have Windows 7 (64bit) with i5-2500K, 1TB SSD on GIGABYTE GA-Z68XP-UD3 LGA 1155
It was great my mobo accepted it bec it did not accept many others before, but now my PC is def slower....
First CPU was at 100% consistently and I could not get new results for Windows Experience because of this error:
.... Unable to start the kernel logger. The logger is in use by another application..... etc
So I disables all but the MS processes in msconfig and rebooted... now my CPU is not always at 100% but the PC is still obviously SLOWER than before.
CPU processes are "normal".. all apps that are open, nothing unusual there.
My current stats are:
CPU: 7.5
RAM: 7.6
GPU: 7.9
Gaming GPU: 7.9
Primary HD: 5.9 (this low for a Samsung SSD?)
And currently my CPU usage fluctuates from 25% to about 50% with just Thunderbird and Firefox (about 35 tabs) open.
Then later it went up to CPU 100% again with Firefox taking up up to 21 on the CPU scale in “Processes”… wth?
FYI with the previous RAM, my PC still worked VERY well after a reboot and open were Thunderbird and Chrome (150+ tabs open). Its when I started to open more browsers and Photoshop etc, then it started to suffer.
Could it be bad memory?
Just ran a spyware scan a few days ago but... ?
Something not showing up in the processes?
I have everything in boot startup disabled besides Avast, Acronis, Realtek Audio, and Intel CUIx3.
I have also rebooted my PC a few times already.
(I want to upgrade to Win 10 now, but I dont want to pile crap on top of crap if there is some issue with my CPU or HD etc., need to solve this before taking the next step...)
Thanks!
to
CPU: 7.5
RAM: 7.6
GPU: 7.9
Gaming GPU: 7.9
Thanks!
