Memory Timings 10-10-10-27
Astralogic
So, memory timings: 10-10-10-27.
Is that crap?
Is 9-9-9-24 better? I'm under the impression that the smaller the number the faster the ram.
I'm currently using this memory, it says the timings are 10-10-10-27. I looked in my bios and the timings were set to 9-9-9-24 so I changed them to match the RAM.
Is that recommended or should I have left it?
Looks like you put this in the wrong section as this is the Monitor/Display section =P
Anyway to answer your question yes lower timings are better but I often find that ram with better timings don't usually make THAT much of a difference on performance with *most* things.
Correct. Not even frame rates for most current Intel systems.
