berninicaco3
- Mar 23, 2013
I built a desktop for myself about a month ago and just ran with the default settings.
But then I remembered that my last setup had defaulted to 1066mhz ram! when it could definitely do more. So I decided to check what my current build was up to in the default settings.
First things first, I'm not that learned on these things. Two days ago I overclocked my friend's old i7 920 successfully, but that was using default suggestions from a step by step guide, and then adjusting downwards a little when it wasn't stable at first. So assume that I know very little. Thorough guides can be hard to find, too.
I'm running an asus extreme4 motherboard with a 3770k processor, and motherboard-compatible ram (patriot something...) which was rated by the manufacturer at 1866mhz and 9-10-9-27 timing at 1.5v
When I checked in the bios under "oc tweaker,"
it had defaulted to 1600mhz and 9-9-9-24 timing.
I also found that asus had its own easy-OC button! woot-- perfect for a noob like me.
I'd heard that the 3770k could do more than 3.8ghz, and I do have a water cooler installed now, so I clicked "4.4ghz turbo,"
left memory at 1.5v
and proceeded to manually adjust the memory to 1866ghz and 9-10-9-27.
If I recall correctly, it didn't boot at all the first time. Or maybe it did, and what it did was,
fail to boot exactly twice, then load windows correctly and appear stable. So I used my computer.
Oddly, when I set the computer to "sleep" and later tried to wake it, it then failed to recover from sleep mode entirely (did not have this problem prior).
And when it did recover, it did the same thing-- failed to boot precisely twice, then booted fine.
So I set it to 4.2, 4.0, and finally disabled the auto-OC feature.
Still the same problems.
Only memory was left.
So I set it back to 1600mhz but left the 9-10-9-27 timing.
Seemed good. Booted up fine the first time. Haven't tested whether sleep works.
But suddenly today, it crashes on me. No blue screen-- just off. Had to restart twice.
So now I've reset the memory timing as well back to "auto," and hoping I'm safely at square one at least and have a stable system again.
What was going on? Why would it fail to boot twice and boot the third time, repeatedly? Why did sleep mode break?
was it strictly the memory speed/timing, or the auto-OC thingy?
and if patriot rated the memory at 1866mhz and 9-10-9-27 timing @1.5v (I know, some memory says at 1.65v-- this explicitly gave those specs at 1.5), why wouldn't it work at those ratings? Why might it even prefer different timing?
thanks for the suggestions!
I still wouldn't mind some performance boost, although it's arguable whether I strictly need it--
and I'm really hoping my system is stable again. Going to test sleep mode again, and reboot a couple times, and see if it's still funny...
left memory at 1.5v
