memoria compatible chipset x299
Sepe
Hi.
I have new Aorus x299 Gamming 3 pro board and i9 7940x core processor. Besides, I have a memory "G-Skill Ripjaws V F4-3000C15Q-32GVR" and I would like to know if it is compatible with chipset x299? Can I add it, or would it be better another model?
Thanks
Hola.
tengo nuevo placa Aorus x299 Gamming 3 pro y procesador core i9 7940x . A parte, tengo una memoria "G-Skill Ripjaws V F4-3000C15Q-32GVR” y quisiera saber si es compatible con chipset x299? ¿Puedo añadirla, o sería mejor otro modelo? ¿Cuál?
Gracias.
kirbyrj
I have that board and I haven't had any memory issues. I think you'd be fine with that motherboard/memory combination as it seems to be compatible with pretty much any Intel setup from a quick google search.
