Medium Gaming / General Use Build
barakandl
Hey guys, you helped me build a computer about 10 months back and it worked out great. Still love my computer and it is working great... thanks! Now i am posting for my room mate as he wants to build something similar to what i got. This was my post from 10 months or go. I pretty much copied the post linked below, but made some changes to fit my room mate's need.
http://hardforum.com/showthread.php?t=1526287
This would be my main computer which i would use for gaming (probably be playing Runes of Magic, Diablo 3, starcraft 2, FPS games). Web browsing, mild photoshop work, etc... general use.
budget between 600 and 800 after tax / ship
3) Where do you live?
Columbus OH. Prefer to order off the net.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case (tower style, need room for 2 hard drives, one optical drive), PSU, mobo, cpu, video card, RAM, sound (on MOBO board fine), NIC card wired (on MOBO board fine), Hard Drive SATA 500gb - 1tb
19" CRT(will be replaced at a later date with a 21" LCD, but do not need that in this build now), IDE DVD Burner, USB keyboard and mouse, speakers.
6) Will you be overclocking?
not likely
Using a 19" CRT that uses VGA (have adapter) plan on upgrading to a 21" LCD soon but not in this build.
very soon. i would like to order by this weekend.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SATA RAID support, IDE device support (for dvd burner), On board sound, on board wired NIC card.
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Plan on using windows 7 64 bit. Have a legit key and install dvd already.
$320 - Intel Core i5-2500K CPU + MSI P67A-C43 Intel P67 ATX Motherboard
$41 - G.Skill Ripjaw Series F3-10666CL9S-4GBRL 4GB DDR3 1333 RAM
$200 - Asus EAH6870 DC/2DI2S/1GD5 Radeon HD 6870 1GB PCI-E Video Card
$70 - Samsung Spinpoint F3 HD103SJ 1TB 7200 RPM SATA 3.0Gb/s Hard Drive
$21 - Samsung SH-S222AB SATA DVD Burner
$85 - Antec Truepower New TP-650 650W PSU
$60 - Cooler Master HAF 912 RC-912-KKN1 ATX Case
Total: $797 shipped
I included a new DVD burner since most current Intel socket LGA 1155 mobos do not support IDE. A new DVD burner is only $20 so it's not gonna hurt ya and it's gonna get you a faster and a little simpler setup in return (i.e not having to go with AMD or a seperate IDE storage card, etc)
I ordered that build and just put it together :)
Everything seams ok but one minor weird thing. On boot up the monitor goes to 640x480. When i enter BIOS setup the image does not fit the screen. The image is too big for the resolution picked and i only get to see the top left corner of the screen. Any ideas??? this might not even be the right place to ask this question
I guess one idea is to move my other LCD monitor in there temporally and see if it displays better.
Check online for current drivers for the video card and firmware/drivers for the monitor. (Yes, some monitors have drivers.)
You should also check the motherboard's user manual to see which BIOS/UEFI settings, if any, you could change to adjust the resolution.
Does this problem affect you when you use the Windows OS?
Windows, monitor, and video card get along just fine. Only issue is going into bios options screen size does not fit. The bios is some kind of GUI bios with mouse support, which is new to me.
For right now it seams all bios stuff got auto-detected properly so it is not a big deal. Monitor is probably just incompatible i am guessing. It is getting replaced soon with a better one anyways.
That's wierd; your monitor should be able to adjust its resolution so you can see all of the UEFI GUI.
