The computer i used as a file storage box for my roommates and myself tragically died. The power supply sparked brightly and smoked. When this happened it also took out my mobo. I would like to use my current desktop as the file sharing box and upgrade to a new desktop computer that i would use daily for games, web browsing etc.
I have built all my computers in the past but honestly i am way out of the scene i really do not know whats what anymore so i am looking for some advice. I can get an employee discount through dell, but i am not sure if a pre built system is what i am looking for.
This would be my main computer which i would use for gaming (probably be playing starcraft 2, diablo 3, maybe some FPS but i have not played one in a while). I do some dvd authoring / transcoding but this is not a priority. Web browsing, mild photoshop work etc.
budget between 600 and 800 after tax
3) Where do you live?
Columbus Ohio. I am not opposed to ordering off the net or picking up stuff at microcenter. i figure ordering off the net would be the cheapest way.
4) What exact parts do you need for that budget? CPU, RAM, case, etc. "Everything" is not a valid answer. Please list out all the parts you'll need.
Case (tower style, need room for 2 hard drives, one optical drive), PSU (probably see next q), mobo, cpu, video card pci express, sound (on board fine), NIC card wired (on board fine)
SATA 500 gig hard drive western digital
IDE Toshiba DVD burner SH-S222A
IDE 320gig hard drive Maxtor
24" wide CRT monitor HP A7217A
Logitech mouse / keyboard (usb) G500 / G15
5.1 boston speakers uses standard jack. i think it is 2.5mm or whatever
When my PSU burned up i purchased a corsair 400w 80 plus efficiency. Only to find out when the PSU burned it also took out the motherboard as it no longer posts or even gives any type of beep code. i am not sure if this PSU is powerful enough for what i want to do so i am willing to get a new one if needed. i have not found if it took out my hard drives yet but if so i can replace those later.
6) Will you be overclocking?
not likely
I have a 24" wide CRT that i will not replace at this time. Run desktop in 1920x1200 and used to play WoW in that resolution. I may upgrade at a later time to similar sized lcd.
very soon. i would like to order by this weekend.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
SATA Raid for hard drives, At least 2 sata ports, i plan on purchasing a PCI Explress vid card, onboard sound and network, able to use at least 2 ide devices
10) Do you already have a legit and reusable/transferable OS key/license? If so, what OS? 32bit or 64bit?
Plan on using windows 7 64 bit. Have a legit key and dvd already.
not likely
