Media boxen rebuild
drgnfang
It's time to rebuild my media box. I've got most of the basic parts covered.
- Media recording and playback
- SD and HD
- $400, yes
3) Where do you live?
- DFW, TX
4) What exact parts do you need for that budget? CPU, RAM, case, etc. Please be very specific.
- Case
- Mobo
- GPU
6) Will you be overclocking?
- No
7) What size monitor do you have or plan to have?
- 24" Soyo
- Next 5-15 days
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? etc.
- Socket 775
- PCI-e x1 (tuner)
10) Do you already have a legit and reusable/transferable OS key/license?
- Yes. Vista HP/Ultimate 32b/64b
11) What parts are you reusing?
- CPU (E7200)
- HS/F (Zalman 8700nt, TRU-90) [Dependant on case]
- RAM (g.skill 2x1g DDR2/667, 2x1g DDR2/800, 2x2g DDR/800) [Dependant on OS verison]
- PSU (Seasonic M12II 430w, Corsair 520hx, PCP&C 610w Silencer available) [Dependant on case]
- HDD (multiple available)
- Tuner (Hauppauge HVR-1800)
ATX or mATX are both possibilities, I'm mainly interested in quality parts that won't crap out on me. I've had 2 motherboards die (both ~ 6-12 months old), and I'm RMA'ing a 3rd Monday.
I know the Seasonic PSU is good (using it right now), but at this point I am unsure of the Corsair and PCP&C.
If you want to keep this as low budget as possible keep your eyes on the Fry's ad daily . They'll likely have a decent mobo and cpu deal one day/week and RAM a couple of days later (or vice versa).
http://www.frys-electronics-ads.com/ (covers the DFW store too)
Since you're not OC'ing, just stick to the stock HSF. You can get a Thermalright bolt-thru kit if you don't want the board to warp.
A less expensive, but still good, tuner is the Hauppauge WinTV HVR-1250. Tunes clear QAM great, like my HD HomeRun! If you have more cash, I'd recommend the HDHR, though.
If you're going with Intel, I'd suggest an NVIDIA GeForce 9300 or 9400 mobo.
If you want to save even more cash, switch to AMD, with a 790G chipset mobo and 4850e or 7750 Kuma. ;)
Oh, and I'd go with 4GB... RAM is SOOOO cheap right now! :p
The Corsair and PC P&C PSUs you listed are made by Seasonic;)
Anyway I concur with Enginurd about everything in his post except for the AMD: If you do go with AMD, get a mobo based on the Nvidia 8200 or 8300 chipsets. Those chipsets can support 7.1 LPCM audio out through HDMI whereas the stock 780G/790GX only support 2.1 audio out through HDMI (A few 780G mobos do support 5.1 audio. Most of those mobos are Gigabyte).
I'll look into the 9300/9400 boards. How do they compare with GB EP43-UD3L + 9400gt (gpu is $38 AR, free shipping)?
The 9300/9400 mobos are way better for HTPCs simply because they support 7.1 LPCM audio through HDMI which is important for HD content. Not a single Nvidia card supports 7.1 PCM audio through HDMI, only 5.1 audio IIRC. ATI's HD4XXX series supports 7.1 audio out though.
In addition, going with a 9300 or 9400 mobo will let you use mATX cases.
Ahh, thats right, I assumed you didn't have a 7.1ch setup. Do you?
