depends on the version.So, if Reds offer the least resistance from the Cherry line of switches, what about Topres? How do they compare?
topre comes in 3 combos afaik. 55g, 45g, and mixed, which has a mix of switches (including 35g depending on which finger is supposed to be touching the key.
Topres have those 35g switches for your pinkies, but im not sure if they have a board comprised entirely of that switch type. If topre has a 35g keyboard, iw ould love to caress it with my fingertips. That would be glorious.
MX red's depress at 40g.
When I read these sort of statements I wonder what I am doing different from other people or what they are doing wrong because I experience none of those symptoms on my MX Blacks. For me, the strong force at the bottom but relatively light at the top makes it so that bottoming out is softened or even prevented altogether.
Also, even after hours of typing, my fingers feel much less tired than on a standard membrane board.
I just find reds easier for long term usage is all. And yes, i'll definitely agree that blacks are less tiring than a membrane board for regular typing. However, i will say that in gaming (i play fps), i do find my fingers get tired on a black board faster than a membrane board because membranes have that collapse feeling where they're easy to hold down at the bottom, and blacks just get more difficult to hold down at the bottom because their spring tension increases. So basically, if you're going to be holding down blacks for any period of time it makes them much more tiring.
It all comes down to what I'm using my board for.
