402blownstroker
[H]ard|DCer of the Month - Nov. 2012
- Jan 5, 2006
Swapping out the 6128 for a set of ES 1.6GHz. First issue is that all the memory is not showing up in the BIOS, only 15 of 15 slots. I have played the DIMM swap party game and it does not seem to make any difference. All 16 DIMMs where showing up and working when I had the 6128s in it. I did apply a 205 OC setting to get the memory flashed. Here is the tpc -dram results:
Looks like tpc is seeing all 16 DIMMs. memtest runs clean without errors. Interesting thing is that only 10MB of L3 cache is reported. Isn't there 12MB? Also memtest does not report quad or dual channel for the memory. You think it is running single ranked mode?
When it boots, the 'Node Interleaving requested, but not enabled error is showing up?
The second big issue is that it is not stable under load. It acts very much like the 6166HE rig when it does not have enough vcore voltage to support the OC. Basically the fah client fires up and after about 30 seconds, the system reboots. It does this at the stock 1.6GHz frequency with the stock vcore value of 1.0500. I have tried bumping up the vcore voltage to 1.150 at the stock frequency and it still does the same. I would expect the system to be stable at stock vcore and frequency let alone a slight vcore bump. To set the vcore voltage I have been doing the following:
At this point I am looking for some ideas/pointers to figure out the memory issue and get it stable( even at stock frequency ).
Code:
[root@ancalagon ~]# tpc -dram
Turion Power States Optimization and Control - by blackshard - v0.43
DRAM Configuration Status
Node 0 ---
DCT0: memory type: DDR3 frequency: 1066 MHz
Tcl=6 Trcd=6 Trp=6 Tras=17 Access Mode:1T Trtp=5 Trc=25 Twr=10 Trrd=4 Tcwl=7 Tfaw=16
TrwtWB=5 TrwtTO=4 Twtr=5 Twrrd=3 Twrwr=4 Trdrd=3 Tref=2 Trfc0=0 Trfc1=3 Trfc2=0 Trfc3=0 MaxRdLatency=46
LDIMM0=EMPTY/EMPTY LDIMM1=OK/EMPTY LDIMM2=EMPTY/EMPTY LDIMM3=EMPTY/EMPTY
DCT1: memory type: DDR3 frequency: 1066 MHz
TrwtWB=5 TrwtTO=4 Twtr=5 Twrrd=3 Twrwr=4 Trdrd=3 Tref=2 Trfc0=0 Trfc1=3 Trfc2=0 Trfc3=0 MaxRdLatency=45
Node 1 ---
TrwtWB=4 TrwtTO=3 Twtr=5 Twrrd=3 Twrwr=4 Trdrd=3 Tref=2 Trfc0=0 Trfc1=3 Trfc2=0 Trfc3=0 MaxRdLatency=45
Node 2 ---
TrwtWB=5 TrwtTO=4 Twtr=5 Twrrd=3 Twrwr=4 Trdrd=3 Tref=2 Trfc0=0 Trfc1=3 Trfc2=0 Trfc3=0 MaxRdLatency=47
Node 3 ---
TrwtWB=4 TrwtTO=3 Twtr=5 Twrrd=4 Twrwr=4 Trdrd=3 Tref=2 Trfc0=0 Trfc1=3 Trfc2=0 Trfc3=0 MaxRdLatency=53
LDIMM0=EMPTY/EMPTY LDIMM1=FAILED/EMPTY LDIMM2=EMPTY/EMPTY LDIMM3=EMPTY/EMPTY
Node 4 ---
Node 5 ---
TrwtWB=4 TrwtTO=3 Twtr=5 Twrrd=3 Twrwr=4 Trdrd=3 Tref=2 Trfc0=0 Trfc1=3 Trfc2=0 Trfc3=0 MaxRdLatency=44
Node 6 ---
Node 7 ---
Done.
Code:
tpc -set vcore 1.150
tpc -fo 1
tpc -fo 0
