MB power connections
jfharper
I have a few questions I wish my MB manual would have elaborated more on, just for my own understanding. Hopefully these are easy to answer.
1. When connecting an exhaust fan to the power source, is it better to use the MB connector instead of the 4 pin PS connector? Is this so the MB can control the fan RPMs? Also, my MB has two system fan power headers and one north bridge fan power header...I assume I use the system fan power header, but I was wondering what the north bridge one was all about?
2. The manual referes to two ATX power source connections on the MB, one 24 pin which I know is the main one, and a 4 pin called a JATXPWR2 for providing +12V to CPU power cicuit...am I supposed to use both of these, or just one? What does the 4 pin one do?
Thank you for your time.
1. Some motherboards aren't going to control the case fans no matter what you do. If you want to control those fans, get a cheap fan controller. Some people will tell you that you should have larger fans like that on a separate 4-pin molex, but I've never had a problem hooking them up to the mobo fan header. Sometimes you even get RPM monitoring.
2. You definitely need to plug in both of the ATX headers. The 4 pin provides power to the CPU.
There's a CPU fan header too right? To go along with the two system fan headers?
There is no difference in powering a fan off a 4-pin Molex connector or a 3-pin fan header on your motherboard. It is getting power from the same place. I prefer the 3-pin fan headers because they look cleaner than a bunch of Molex connectors hanging around in your case. Also, you can monitor your fan RPM on most motherboards when they are plugged into the 3-pin headers.
I would say use the 3-pin if you can.
Some high voltage fans will blow out the headers on the mobo though. Depends on what you're using. If they are just normal fans, you should be fine.
I was actually going to ask a similar question. I just finished building my first PC in years and prior to this all I had seen was a 20 pin ATX connection. Now this new MB (Asus A8N-E) has a 24 pin and the 4 pin.
My PS was setup to do either 20 pin or 24, so I was wondering what the difference is -- if it's a PS difference or a MB difference where it requires different power or what.
Can we elaborate more on the functions of the different connectors?
