Maximus Formula skyhigh voltages, must be error
8 Ace
I was a bit concerned at first when the alarm went off, but all the temps and fans stayed normal.
It seems that it might/must be a reprting error from Probe. Anyway I was just wondering if anyone on here has experienced this, doing a little research threw up at least one other case with the exact same readings.
Any thoughts on the matter :)
PC Probe II V1.04.19B is red flagging voltages as follows:
1.2VHT= 4.08v
NB Core=4.08v
SB Core= 4.08v
DDR2 TERM=4.08v
Memory= 4.08v
CPU VTT= 4.08v
nb
The other case I came across was using a different mobo and processor.
That cant be correct, your cpu and memory would be toast. Something wrong with that software.
