My FSB will not go past ~440 with my Q9550 E0.
So I know this has been an issue for a while, but I was wondering if it has been resolved. I am currently running the Rampage Formula Bios 0803 and I heard from somewhere that setting the CPU Skew Control to 100ps and NB Skew Control to Normal is supposed to eliminate the wall issue, however it has not worked.
Does anyone have a Maximus Formula x38 with a 45nm quad that is able to get past the wall? I don't want to give up until I absolutely know that you can't.
I am currently running 3.7ghz at 435x8.5 with 1.23 volts, so I know this chip can go way higher. Max temp at this setting is 61c with Orthos maximum setting. Thanks!
