So I'm playing around with an old G4 (yes, I know... boo, hiss, etc. etc.
) and I'm trying to overclock it.
Now, overclocking a 6 year old Mac is a little bit different than overclocking a modern PC; it involves resoldering little surface mount resistors on the CPU module. Call me masochistic if you must, but I like this more than I like overclocking PCs. It's more of a challenge.
Anyhow. The CPU module in question has two 533MHz PowerPC 7410 (G4) processors on it, and they have external L2 cache. The cache chips run at half the processor clockspeed (so 267MHz in this case). The chips are Samsung branded, model K7A403609A-QC27.
Here's the question:
I found a datasheet for-I think-these chips, here:
http://www.ortodoxism.ro/datasheets/SamsungElectronic/mXvvsrw.pdf
Looking at page 2, it says that the VDD and VDDQ specs on this thing are 3.3v; I know that they're run at 2.5v in the Mac. My understanding from what I'm reading is that I should be able to dump 3.3v into these things with no problem at all. Am I reading the spec sheet correctly, or am I going to crater one of these cache modules?
Thanks.
Thanks.
