I'm looking for a 12v fan (I suppose it could be 5v or 24v instead).
I'd like to keep it under a couple watts if possible.
My optimum size would be ~80mm.
I have a relatively sealed enclosure (~36"x6"x6") with quite a bit of resistance that I'm trying to keep cool.
What kind of fan/setup would you guys suggest? Case fan? Squirrel cage type? Push/Pull, one on each end?
I figure this subforum is about as knowledgeable as it gets while talking about 12v cooling applications.
Thanks!
Thanks!
