Max Keyboard Blackbird TKL
meh. don't really see the point in paying so much just because it's backlit. i'm sure anyone who's looking into buying a mechanical can already touch type. ;) leopolds will always get my vote. although, those usb ports would be pretty useful for charging a phone or something.
$130 for those wondering since the price isn't posted in the title or the OP.
About 2x the sale price of a Costar (same OEM as Filco) built Cooler Master Quickfire Rapid. tenkeyless.
I touch type most of the time, but when I game in the dark it's still handy, and it looks good, especially when your hunting for one of those keys you don't use often.
It is more expensive than a costar build but it is good quality and has double shot injection molded key caps. Put that in your pipe and smoke it! All other backlight keyboards except the Deck's use laser etching or other techniques that are inferior. I'm ordering a deck or I would be purchasing another blackbird, however the deck is going to cost me about $50 more, but I want good keycaps and a tenkey for work and I'm willing to pay for what I need.
Negatives:
- The USB ports cannot be used for charging.
- Also I have had problems with this keyboard on my Z87 chipset, something about the USB on my motherboard kind of sucking, but there's work around and I still use this as my primary at home. (plug a flash drive into it, or plug the keyboard into a hub.) It works on my other 5 computers just fine though.
Not all mechanical keyboards are created equal, I'm returning my Thermaltake Poseidon because although it has brown switches it just isn't as nice to type on. I bought it thinking I overpaid for the Blackbird but I would pay it again in a heartbeat after trying to find a second KB as good.
This isn't really comparable to a CM keyboard, CM's do not use doubleshot keycaps. If any of you find a manufacturer selling a doubleshot keycap set for backlit keyboard then maybe you could mod a CM backlight board to have better caps but I'll bet it costs over $50 for such a keycap set if they were even available. MSRP is $150. so it's $20 off with free shipping is the deal. Comes with a wrist rest as well.
Here is the comparable CM board, although we do often see them for around $100, I sorta love hate the design though because you can keep the 10key, but it just has ABS laser etched keycaps and they are not standard sizes.
http://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=74
I got my CM with tenkey for around 70ish months ago.
With Backlighting? Even then it's at least another $50 to upgrade to doubleshot PBT caps.
http://www.amazon.com/Max-Keyboard-...ref=sr_1_1?s=pc&ie=UTF8&qid=1396613272&sr=1-1
Not sure what the difference is between Nighthawk and Blackbird, but the Nighthawk with 10-key is same price with same Cherry MX Brown
Different manufacturer, nighthawk is made by iOne. The Blackbird is higher quality, again, it is one of the only backlight keyboads to offer good keycaps. The other being Deck, and thats all I have been able to find. Neither sell their doubleshot keycaps separately.
Tempted, but I want orange backlight & since I can get a ducky with orange for 10 bucks more I would go that way... I have been waiting for a decent savings over this one.
https://mechanicalkeyboards.com/shop/index.php?l=product_detail&p=555
But ducky only has cheap ABS laser etched keycaps, so to me your paying more for less. Ducky is good I just eliminated them from my decision due to keycaps. If orange is important though your options are certainly much more limited. Deck offers a keyboard more similar to the ducky with all it's lighting effects only with doubleshot keycaps, it's about $180 though, so it's pretty obvious that ducky had to cut costs on those keycaps to get the price down. If ducky offered doubleshot keycaps I would jump on it though, even if it was $200.
Hey this keyboard isn't for everyone, it's obvious that you can get a mechanical for less just not with the same features. Like I said I just bought a Tt Poseidon with cherry browns that has backlighting etc for $80, but I do not like it and it does not give the same attention to detail as this one, the stabilizers suck, the keycaps are cheap laser etched and do not have the same feel when I type on them. It's going back today. I'm not here to convince anyone that they need this though, but just because you can get another mechanical for less doesn't mean much IMO.
that's pretty sad...
Just because someone looks at the keyboard every once in a while while typing doesn't mean they're hunting-and-pecking. :rolleyes:
I generally touch-type, but I do often take a glance at the keyboard to reset my point of reference. I also don't touch-type "correctly," never use pinky fingers, and have zero use for the whole home-row stagey, but that doesn't stop me from consistently typing above 100wpm without looking at the keyboard for long stints.
And then there's the matter of keyboard shortcuts and/or gaming use. Those inputs don't "flow" like normal typing, especially little-used key combos or media hotkeys. Being able to see your keys can be a huge help in such instances.
By definition if one looks at his/her keyboard they are not touch typing.
i really don't understand why you care so much about doubleshot caps, especially enough that you think $50 extra is worth it for them. it really doesn't matter.
I glanced at the keyboard for a split-second before starting this line, but otherwise typed this entire line (and the rest of this post) without looking at the keyboard.
This doesn't qualify as touch-typing to you? No glances allowed? If I lose my frame of reference, I have to reset it by blindly groping for the nubs on F and J?
Yeah, screw that, a quick glance is faster. One quick look to make sure I'm not shifted over by a key and it's off to the races. It's still touch-typing :rolleyes:
Maybe not to you, but they are worth it to me. Like I said, my thermaltake went back, just had a cheap feel, and part of that was certainly the cheap keycaps. To say it's not worth extra money for "premium" anything is up to the individual to decide. At least with doubleshot you will never wear away the symbols on the keys.
But hey your car will get to work and back whether or not it is perfectly painted or has a scratched up or peeling clearcoat.
Hell I'm about to drop $50 more than this one just to upgrade to doubleshot PBT keycaps, and to avoid having two of the same thing... I already wore smooth some of the ABS keycaps on my board at work in only a years time.
I can't keep mine clean enough to warrant paying over 130 and the fact that I replace mine every two years. To each their own.
