Hi guys,
While anxiously waiting for the IB to come out, I am looking around for the case for my future SFF gaming rig. Once IB is out, I would post a different post for some recommendation the rest of the rig
I have 2 general ideas in mind right now. If you were to build a mid range gaming rig, which one would you pick? Or do you have a better idea?
option 1:
LIAN LI PC-V354B
+ some Corsair PSU (500-700w) (depending on how much power do my mid range GPU needed)
+ mATX mobo
option 2:
SILVERSTONE SG08
+ buildin 600w PSU
+ mITX mobo
I would go for a much better/well recommended case like TJ08-E(15.16" x 8.27" x 14.72") but that case is a bit bigger than my book shelve (13" x 13" x 17")
I bet some of your guys would said that cooling might be a problem with these case
I might get a CORSAIR H60/H80 if the stock fan cannot handle the heat while not OC.
On a different note, will a 64GB ssd big enough for OS + application? I would rather save the money for a better GPU and get the Crucial M4 64GB than the 128GB; make sense at all?
and thank you for your time
option 1:
LIAN LI PC-V354B
+ mATX mobo
option 2:
SILVERSTONE SG08
+ buildin 600w PSU
+ mITX mobo
