mATX mobo in atx case
bazookaworm
Do all matx mobos fit in a atx case? I have a matx mobo( Asrock alivenf6p-vsta) and although 4 screws line up in my case, there is another 2 parts in my mobo where screws are supposed to go but no screw holes in my case. Someone told me ALL matx mobos work in a atx case, is this true?
Btw the case is some OEM case by acm.
thx
Ouch, apparently not. It is rare that a case is not predrilled for both and I have seen ones like you are describing advertised as fitting both but with some of the supports of uATX not implemented. Usually the missing ones are on the (assuming a mid tower design) bottom edge and it may be that the manufacturer decided these were really not needed. I do not agree but once the components are installed with some care it could be argued that it does not take a lot to sufficiently secure the board.
Since there would be a fair amount of expense, I would mount the cpu and memory out of the case, mount the board and install any cards gently, it should be fine. You could also glue some nonconductive "pads" even a wood block to the motherboard tray under the unsupported area of the board just to give it a little "backing" when pressing add-in cards into their slots.
Anyway its all your call, I would not like it either.
Get a drill and tap and make your own holes o_O I've done that with many a Gateway OEM case when I replaced the mobo. Also, one thing you might find amusing is getting the I/O shield to line up with your mobo in an OEM case :)
Yea, the I/O shield was such a pain, I felt like just leaving it out altogether. Do you guys think I can get away without screwing the bottom 2 holes in? I also noticed the mobo shook around a bit when i tried to plug the monitor in too. Idk if I should just buy a atx mobo or not, you never know, perhaps an ATX mobo wont fit neither :p
That does not sound right, even with just 4 screws the motherboard should be firmly held. Do you mean that in plugging in the monitor into a video card there was some movement of the video card ? The card should be fairly firmly held by a screw on the top of its bracket that also screws into the case. If On-board video where the monitor plugs into the conncector directly on the motherboard at the I/O backplate the 4 existing screws should be plenty tight and sufficient to not allow the board to move. Something still seems wrong.
