mATX/mITX Mobo, CPU, Case, PSU for tiny power build
friend'scatdied
1) What will you be doing with this PC? Gaming? Photoshop? Web browsing? etc.
Photoshop, digital audio and video workstation software (Ableton Live, Adobe Premiere, et alia). Small amounts of heavy gaming -- looking to play Skyrim and Battlefield 3 at maximum settings (less AA and AF), but I'm not prepared to upgrade the GPU for it.
$400-600. Yes, include tax and shipping.
United States, New York City and Central NJ. I have access to the NJ MicroCenter.
Motherboard, case, CPU, PSU. I don't want or need an optical disk drive.
ATI Radeon HD 5850 (RBE undervolted to 0.95v)
Intel X25-M G2 160GB
Hitachi DeskStar 1TB 7200RPM
Patriot G2 DDR3 1600MHz 4GB x 2 (8GB kit)
6) Will you be overclocking?
No, I've never felt the need to overclock. The Q9550 at stock felt fast enough to me.
1080P.
I can buy whenever prices are right. I'm looking for some value. I'm comfortable finishing out the build early in 2012 if necessary.
9) What features do you need in a motherboard? RAID? Firewire? Crossfire or SLI support? USB 3.0? SATA 6Gb/s? eSATA? Onboard video? etc.
USB 3.0, and the ability to fit super-long video cards. But I need it small. I want a small system. micro-ATX or mini-ITX is a must. The smaller, the better. I'm willing to pay premiums for small volume, but not at the expense of upgrading capability (my last system was a Shuttle and I don't want anything proprietary this time around).
Yes, Windows 7 Professional 64-bit.
I'm comfortable with the performance my HD 5850 provides and I'm pretty confident it'll be a golden overclocker if necessary. I hope what I'm asking for isn't too ambitious -- just a small-footprint system with a great bang-for-the-buck CPU. Thanks guys.
$59.99 - MSI H61M-P21 (B3) LGA 1155
$219.99 - 2500k
$84.99 - CORSAIR Enthusiast Series TX650 V2 650W
Total: $364.99
As for your link to the RAM, it doesn't work. As long as the RAM is rated to no higher than 1.5v, then you'll be fine.
Case wise, I have no idea what kind of good mATX case to recommend.
$219.99 - 2500k
Total: $364.99
just remembered he has access to microcenter, which has 2500k at $180...
don't remember if they have any P67/Z68 mITX mobos with the combo discount though... check the circular?
EDIT: http://viewer.zmags.com/publication/d8ebaa79#/d8ebaa79/28
AsRock mATX z68 for $36.. not bad. their only mITX is a gigabyte h67 for $85
That ASRock motherboard probably only has a 1 year warranty.
Link doesn't work. It says, "No Product Found"
Again, please find out what RAM you have. Depending the RAM you have, you may have to ditch that Patriot RAM and get an entirely new set.
close. http://www.newegg.com/Product/Product.aspx?Item=N82E16813157252
Manufacturer Limited Warranty period (parts): 2 years
Manufacturer Limited Warranty period (labor): 2 years
So far, Newegg is the only official source I've seen that AsRock Z68 mobos have two year warranties. I haven't been able to find a source on AsRock's website confirming that two year warranty. Considering that Newegg has been wrong in the past when listing certain information about parts on their site and the fact that AsRock generally has one year warranties on their motherboards sold in North America, really can't trust that Newegg source.
So unless you can find a source from AsRock that confirms what Newegg says, really can't assume that mobo has a two year warranty.
yeah, i guess Newegg is wrong since ASRock's website says only 1 yr warranty
http://www.asrock.com/support/index.asp?cat=RMA
Would prefer mITX.
As for the RAM, it's 1.5v. 9-9-9-24.
I was eyeing the Silverstone SG07. Are there any mATX cases that can compare reasonably on size?
I believe that there isn't a better mITX case (that can handle a large video card) than the SG07. As for the board and processor:
$300 - Intel Core i7 2600
$70 - Biostar TH61
The Hyper Threading on the i7-2600 (non-K since you're not overclocking, so there's no need for any unlocked CPU multipliers) will aid you with your video editing. If you're using Adobe Premiere Elements instead of the "full" Adobe Premiere, you can get by with the Core i5-2400 in lieu of the i7-2600.
Before I forget, call your "local" Micro Center to see if its Intel processor/motherboard combo deals also apply to the above. Regardless, MC has much cheaper processors than NewEgg.
$250 -- Core i7-2600
$100 -- Gigabyte GA-H67N-USB3-B3 LGA 1155 H67 mini ITX (USB 3, SATA 6, eSATA)
Tax rate appears to be 1.035% so $362 total.
Leaves $238 for a PSU and case. (Some cases I would suggest are in this set of search results.) I think my favorite based on your criteria is the Lian Li PC-Q08. By removing the lower hard drive cage you can put in 12 inch long GPUs that are two slots tall. (You still have plenty of room for hard drives.) It also takes standard ATX PSUs. It's available in black for $110 and silver for $120.
If you go black, you have $128 for a PSU. I would suggest going fully modular if possible, but the only thing I can find in that price range goes over budget when you take shipping into account.
$127 ($11 shipping) -- Seasonic SS-560KM Active PFC F3, 560W ATX12V V2.3/EPS 12V V2.91, 80Plus Gold Certified, Modular Power Supply
Alternatively, you could go semi-modular:
$92 (plus $10 shipping) - SeaSonic M12II 520 Bronze 520W Power Supply
$110 (before $10 MIR) - CORSAIR Enthusiast Series TX650M 650W High Performance Power Supply
$100 (plus $10 shipping) - SeaSonic M12II 620 Bronze 620W Power Supply
$120 (before $20 MIR) - CORSAIR Professional Series HX650 (CMPSU-650HX) 650W Power Supply
Out of the semi-modular camp I would go with the Corsair HX650, especially with the mail in rebate.
Even with fully modular cables you're going to run into cable management issues (the cables will probably be too long.) But the fewer you have to stuff in there, the better.
Considering that the OP is sticking with his 5850 for the time being, I believe that the SG07 would be more appealing to him due to its comparatively smaller profile.
If the OP is willing to consider cases that come with PSUs, then I would recommend the SG-07 too. It does look like the included PSU is a decent one, and is ATX sized so replacement should be easy enough if you get one of the same length. It does look like a cabling nightmare though with that GPU stuffed in there. Zip ties might help.
Who F'n cares if its a z68 board for 36 dollars.. You have to levy the warranty period against what your paying..
As far as cases go I have dabbled a good little bit in SFF & I can tell you that both mITX cases listed are a PAIN in the ass to work in.. the sg07 simply because its tight & the q08 because its like 8 screws to get the side panels off & you always have to touch it with kid gloves..
If it were me & your looking for something small & good looking I would go a little farther off the beaten path given your budget..
280 for the 2600k
36 for the asrock z68 mATX board listed
170 for the FT03
120 for a hx650
Still a pretty small footprint though it would be larger then either of the mITX (esp the sg07).. Great looking case & you make less compromise's in the log run..
I recently traded my TouchPad for a NIB i7-2600k.
Do you guys think I can fit a H60 in a Silverstone SG05BB-450 if I mount the radiator where the front 120mm is? Bearing in mind the 3.5" HDD, 2.5" SSD and no optical drive. Since the processor is unlocked I might as well try to get some more out of it.
Unless there is a mATX with similar volume to the SG05 that I'm missing? The size and form factor of the SUGO are ideal for me.
