Matchin MOBO with memory
yes it will, just look at the specifications of the motherboard and
"DDR Standard DDR 400 (PC 3200)"
you shouldnt have a problem with it! Good luck
I'm sure you can get memory that is just as good cheaper than that. $300 for 2x1GB sticks of DDR1 memory is overkill. I bet you can find the same sticks used in the forums for less than $200.
