[FONT="]I will be parting a new machine this MONDAY 3-09-09. Would like some help massaging the price out or subbing components with comparables for cost savings.
Every dollar saved is 1 day less the wife will bitch about it.
Also can I re-install my windows XP pro on a new computer? The old computer will still be in-use as a movie server. A Friend said they(XP) lock to the CPU and are not transferable? I would hate to buy Vista/XP with Windows 7 around the corner but will if i have to.
1)Gaming, photo editing, DVD ripping, MS office, web etc Pretty much everything.
2)Would like to stay under 1k total cost
3)Houston TX
4)I require CPU, MoBo, RAM, HDD, Case & PS, pretty much everything but vid card, I will be using a 4850 for a while longer.
5) Only reusing a sapphire 4850
6) Mild overclock but not going to go crazy. Wont overclock if it is going to cost me anything more initially.
7) 22" widescreen monitor willnot be changing it in the near future.
8) Will purchase tomorrow Monday 3-09-09
9) Sound built in on the MoBo all else is gravy.
10) I have XP Pro on current Machine. But will buy vista if i have too. See above comment.[/FONT]
[FONT="]** i would like to stay with, Newegg, Microcenter, Fry's, Directron, Amazon, tigerdirect.... would consider another verndor but not a fly by night company.[/FONT]
[FONT="] Here is my current Build.
[/FONT]
[FONT="]CPU= Intel I7 920 http://www.microcenter.com/single_product_results.phtml?product_id=0300438[/FONT]
[FONT="]Ram= 6gb G.Skill 1366 http://www.newegg.com/Product/Product.aspx?Item=N82E16820231225[/FONT]
[FONT="]MoBo= Asus P6t http://www.newegg.com/Product/Product.aspx?Item=N82E16813131359[/FONT]
[FONT="]CDR= Sammy 22x http://www.newegg.com/Product/Product.aspx?Item=N82E16827151173[/FONT]
[FONT="]HD= WD 640 black http://www.newegg.com/Product/Product.aspx?Item=N82E16822136319[/FONT]
[FONT="]PSU= Corsair 850 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139009[/FONT]
[FONT="]OS= Win Vista Home 64 http://www.newegg.com/Product/Product.aspx?Item=N82E16832116488[/FONT]
[FONT="]Case= CM Cent 590 http://www.microcenter.com/single_product_results.phtml?product_id=0282871[/FONT]
[FONT="]Total cost with shipping and Tax 1036 and some change there is also 20 MIR but I never count those as they are iffy at best.[/FONT]
3)Houston TX
[/FONT]
