Megalith
24-bit/48kHz
- Aug 20, 2006
Just earlier today, Malwarebytes pushed a “bad protection update” that led to high memory consumption and CPU usage, but the company already has a fix. Users who are having trouble installing it may first try terminating the mbamservice.exe process in task manager or reinstalling the software.
To resolve these issues simply start MBAM and check for new updates. The program will automatically download the new update and install it. If your computer is unresponsive, you can either terminate the mbamservice.exe process in task manager and restart Malwarebytes in order to try and download the new update. As a last resort, you can uninstall MBAM and reinstall it.
