Status
Not open for further replies.
heatshiver
It looks like the original seller of these is no longer around, and the demand for them is still good, so I've started a new thread to sell what I have.
Information
This is for the older version of Malwarebytes which still recognizes the lifetime licenses. The program cannot be updated due to this, however, the database definitions can be updated to the latest. If you accidentally upgrade to a newer version, you can still uninstall and reinstall the old version and use the same license.
The version is v1.75, and requires both the ID and Serial Number.
Price
$10 per license
Buy 1 Get 1 FREE deal!
I accept PayPal Friends and Family (Gift), or Google Pay.
Instructions
To download Malwarebytes use the following link.
To ensure that Malwarebytes will continue to update the threat database (but not upgrade the program version) do the following:
*If you are asked to update before you can complete the following steps, select "Later". If you accidentally update, uninstall the program, reinstall and perform the following steps:
1) Click on "Settings" at the upper-middle of the window.
2) Click on "Update Settings" from the menu on the right.
3) UNCHECK "Check for program updates when checking for database updates."
To insert your license:
1) Click "Activate" in the upper-right corner of the window.
2) Insert your license info.
3) Click the "Activate" button.
If you have any issues, please contact me. Heatware
Thanks for that, guys! Didn't even know, but touted now in the first post.
And yes, it works with Windows 10.
Good lord B1G1 how many of these things do you have? LOL Kinda wish I had more computers just so I could pick a couple up as that's a smoking deal.
Yes it is, you just need to make sure you turn off program updates so it dont download to the newest version. The database will still download the updates for the newest virus/malwares.
Was there a specific reason it won't it work on newer versions? I have a lifetime key that I've been using for years now (picked it up on newegg when they were dirt cheap), currently on version 3.7.1, still lists me as "Edition: Premium, Status: Never Expires". As far as I know, the only difference is that it's referred to as Premium now, when it was called Pro before.
Either way, MBAM is the shit. Free bump for you, glws.
I picked up a lot, I figured I would use them throughout a lifetime! I like to build, even when I shouldn't, so they come in handy.
I'm not quite sure, they never worked on new ones (and I tried), but i was okay with it as long as the definition database was updated.
BUMP. Just wanted to let everyone know that the definition database update does not work automatically, even though I have it setup in the schedule task to update. I found it intermittent when updating. Currently set at 5/24/2019 at 9:00AM. Recover if missed by 1 hour, and repeat every 1 day(s). Wake PC to perform update was also checked.
Anyone else have a better setting?
UPDATE 10-17-19: the auto update does not work well with windows 10. It does work with windows 7.
Reactions: cnp
Status
