- Apr 27, 2006
Ok I set up my first water-cooling loop tonight. I didn't think about it till now, but with the solid black tubing, I have no visual idea how the water is flowing.
I filled up the res and turned the pump on for a few seconds till it drained, then repeated that a couple times until it is at the same constant level. It seems to be working fine, I'm seeing the water spit back out from the reservoir inlet, so I'm assuming everything is ok.
Will the rad fill up completely by itself, or do I need to start tilting the case around and upside down to be sure?
Just looking for some peace of mind I guess.
http://img266.imageshack.us/img266/861/img0367j.jpg
http://img410.imageshack.us/img410/5300/img0368g.jpg
