making Collect Data file - why does 'Run As' say NT Authority/System?
Discussion in 'Operating Systems' started by HAL_404, Nov 23, 2019.
Thread Status:
Not open for further replies.
  1. HAL_404
    HAL_404 Limp Gawd
    393
    Dec 16, 2018
    I want to try to increase FPS as per the video below by making a Collect Data file (see screen capture and video below) but 'Run As' says NT Authority/System instead of System. When I click the OK button I get a pop-up asking for the NT Authority/System password. I don't recall entering an Admin PW, just the 4 digit PW for when I log in at the start up screen when I boot mu PC.
    How to I change 'Run As' from 'NT Authority/System' to just 'System' or where/how do I add/change the NT Authority/System PW?
  2. muz_j
    muz_j Limp Gawd
    220
    Jul 13, 2014
    ...I am going to assume you are not trolling, although I suspect there's probably a 50% chance you are trolling.
    This is a hoax video / misinformation.
    This particular YouTuber has a history of doing hoax technical support videos.
    Read / scroll through the YouTube comments and you should appreciate this is a hoax / joke.
  3. HAL_404
    HAL_404 Limp Gawd
    393
    Dec 16, 2018
    definitely not trolling - thought there might be a slight fps increase (not 2x lol) just wanted top see if it made any difference. Thanks for the heads up ... thread will now be closed
    muz_j likes this.
Thread Status:
