delorean76
- Oct 3, 2005
About a month ago my grandma's 1 1/2 year old Emachines PC fried (I was told a bad PSU messed up the mobo and Celeron 2.6ghz CPU). It was cheap so it wasnt that big of a deal, plus all she practically uses it for is solitaire.
Around this time I had been considering to build my own PC for the first time so I figured I could give my PC to her, moving any good parts from her old PC into mine: Compaq Presario 2.6ghz P4. Our PC's are quite similar. I connected her 80gb Maxtor IDE hdd to my PC as a slave, just to make sure all the info was there, and it is.
After getting some help here, I purchased all the parts for a new gaming PC that will be arriving on 10/11 so Ive been getting my current PC ready for her and moving my parts that I'm keeping from the PC. The only problem I've encountered so far is figuring out how to make her hdd eventually boot on my PC. Being the newbie I am I figured if I set her hdd as the master it would magically boot up. After trying that out and reading around this forum and the faq's, I see thats not the case.
I found out Im going to have to make her hdd the boot drive, instead of my current boot drive using MaxBlaster from Maxtor. Is it as easy as creating that partition on her hdd though? Ive never created a partition, etc. before.
How will this affect my hdd? So far I've simply copied the 5gb of info on her hdd to my 80gb IDE master hdd and backed up my master hdd to my slave 80gb IDE hdd. If for some reason, after I make her hdd the bootable drive, that I need to make my current bootable hdd bootable again, can that be easily done? Will I have to somehow make my current bootable drive also bootable for my new PC?
Thanks for any help, this stuff has really confused me
