Dangman
Ninja Editor SuperMod
- Dec 15, 2005
- What app is using 70% CPU usage? That's just it, the only thing running at the time was the Task Manager.
Look under the Processes tab in task manager. It should tell you what app is using 70% of your CPU.
Also, try emailing Abit's customer support. Tell them your problem and see if there's chance that's it is motherboard related.
- Have you done any kind of "tweaking" on XP? Like turning off certain services, removing certain windows apps, etc.
- What apps are being loaded up at startup?
- This is a fresh install on a new hard drive correct?
- What new hard drive did you buy?
- Run Prime95 and see it passes. If it doesn't, then something is wrong with your CPU.
If it was this slow on both your old and new system, there's got to be something wrong with the way you're installing the software. Walk us through how you usually install XP on a system, Include what every software you install afterwards, what drivers you install, etc.
