More info of air compressor destroying my PC, see here: http://hardforum.com/showthread.php?t=1816821
1. Budget
I’ve got some money. I just don’t want to spend too much. I won’t list a budget. I just want best bang for the buck so value.
2. Components
PSU
RAM
Motherboard
APU or (CPU and Videocard)
I’d like to get bluetooth capability and could use a 80mm fan. My case uses 120mm and 80mm fans.
3. Usage
Video/graphics editing
I use a TV card, too.
Lots of Virtual Machine usage.
Light gaming but nothing crazy.
Internet, etc.
4. Features
USB 3.0
At least four HDDs will be used.
I have a DVD drive that’s IDE/PATA. IDE seems to be fading out, so I can just buy a cheap SATA DVD drive.
I already have a soundcard and wireless network card and TV card. My graphics card is too old, and I suspect bad.
5. OC
Not on this rig.
6. Durability
As long as possible. I don’t always update or upgrade, but I want to keep my options open.
8. Ideas for Components
Motherboard
ASRock FM2A88X Extreme4+ FM2+ / FM2 AMD A88X (Bolton D4), $76
http://www.newegg.com/Product/Product.aspx?Item=N82E16813157468
PSU
Antec BP550, $65
http://www.newegg.com/Product/Product.aspx?Item=N82E16817371016
RAM
Crucial Ballistix Sport 8GB (2 x 4GB) 240-Pin DDR3, $73
http://www.newegg.com/Product/Product.aspx?Item=N82E16820148662
APU
AMD A10-7700K Kaveri, $160
http://www.newegg.com/Product/Product.aspx?Item=N82E16819113360
Plextor DVD Drive, $30
http://www.newegg.com/Product/Product.aspx?Item=N82E16827249084
I'd like bluetooth support and motherboard doesn't have that built-in, so I'll probably buy some add-on device or card. I'll add a cheap fan, too.
9. Retailers
I don’t care. I use Newegg and Amazon a lot.
1. Budget
2. Components
PSU
RAM
Motherboard
3. Usage
Internet, etc.
4. Features
USB 3.0
5. OC
Not on this rig.
6. Durability
Motherboard
PSU
Antec BP550, $65
RAM
APU
9. Retailers
