Did you figure out what the problem was? Are we on the "new" server now?
Slows down every so often but it usually just takes a refresh to take off again. Nothing major or annoying.
No errors but major slowdowns on and off.![]()
I'm not sure if this is what people are talking about, but every time I view this forum, the CPU usage starts to rise and my entire system starts bogging down. After few minutes, I check the task manage and it shows my CPU usage as near 100% for iexplore.exe. If I close the tab or window with the Hard forum on it, or just refresh the tab, the problem goes away, but it just comes back again a few minutes later, and it gets REALLY bad if I happen to have more than one Hard Forum window open.
Something on this forum is definitely causing massive CPU usage after a little while. It "might" have something to do with the banner ad, because I am currently noticing that the banner ad is not changing right now, and the CPU usage is not climbing.
Usually, the banner changes, but I'm not sure why it's static at the moment. I'm going to hit "preview post" right now and see what happens....
Okay -- the banner add is moving again, and the CPU has immediately started climbing. In the 60 seconds since I hit preview (which refreshed the window) it's already hitting the high 30's.
Thanks to anybody for looking into this,
Larry
