MagLite 3W LED drop-in
MagLite just released their new high power LED drop-in for their infamous flashlights.
They can be found right now, in the sports counter section of most WalMarts.
What is really nice about them, you can pop one of these into your 2D MagLite, and totally own one of those 6D Cell MagLites.
A review of the module, with comparision beamshots can be found here:
http://candlepowerforums.com/vb/showthread.php?t=119665
If you read in the candle power forums these arent the best upgrades for your maglite. Unfortunately maglite decided to put cheap stamped metal "heatsinks" around the LED circuit. After about 20 mins your light intensity goes down almost 50% because your LEDs and circuits heat up too much...
Sounds like that makes it a "hot" deal ;).
i bought the converstion one from diamond before a 3watt and works awesoe, i paid 25 for mine..
Owning other flashlights is one of my favorite things to do.
All ownage is accomplished in the first 10 seconds. Thats all that matters.
I got one for my mini-maglite (and a rear cap switch) and one for my 4 D-cell Maglite.
But I payed under $15 for both (shipped) from eBay from a brand called NiteIze
'Bout time MAG jumped into the LED game!
Looks like I'll be buying one of these for my parent's 2D.
I have been looking at local wal-mart and home depot stores and have yet to locate this upgrade.
Reading the link to the CPF thread, it seems as though Mag is going to release a 3W LED flashlight in the 2AA and 3AA form?
Can anyone confirm this, whether or not it's already out?
Also, does the light permenantly dim after 30 mins of use or is that just until it cools down?
Thanks in advance.
Only until it cools down -- it only dims because of a thermal regulation circuit (which should prevent the LED from destroying itself too quickly).
If we were brits and not mostly Americans, we would be calling these things "torches" lol
By the time you buy the flashlight then the LED upgrade you'd be better off getting a real tactical flashlight bright enough to cause temporary blindness.
