Machine wont even POST
ashrack
A friend of mine just delivered me his machine since it died. He says that it happened whilst working on it, he got some BSOD windows error. He then did a hard reboot and now the machine wont even beep.
I tried pulling out every card incl. GPU and RAM and also all of the molex connectors but the machine still wont even beep.
Specs:
865PE Neo2-LS (http://www.msi.com.tw/program/products/mainboard/mbd/pro_mbd_detail.php?UID=433)
512DDR
P4(dont know the clock)
SATA HDD
The machine is about 1.5years old.
ps. I dont believe it could be the heating since the fan is HUGE and louder than my hair dryer..
Any ideas?
If you don't get a beep, it's typically a CPU problem. Try re-seating the CPU in the socket, and the HSF on the CPU. Also try re-seating the vid card and ram. Try booting with just those 3. Of course, make sure you have all your power connected.
dandragonrage said:
I'd say it's more often the motherboard or power supply. But CPU is not impossible.
I've already had 2 scenarios where CPU was the problem. And in both scenario ECS K7s5a wa the MOBO
tried it, didnt work
