Macbook Pro
Discussion in 'Operating Systems' started by StefanPeeters, Nov 20, 2019.
  1. StefanPeeters
    StefanPeeters [H]Lite
    115
    Oct 7, 2013
    Hi,
    My macbook crashed and installed a new hard disk. My mac is form 2011 (OSX Lion). When I want to install the OS again but that is not possible. I took the hard drive out and placed it in an Imac from the same periode. I installed High Sierra and placed it back into the macbook. Booting was no problem until I installed updates. The first time it asked me to reboot. This was no problem. The second time when I installed updates the macbook starts to hang. Now I can't even boot my macbook. I tried all the commands but no result. When I put the hard drive in the imac it boots fine. When I do a clean install on the imac and place it back into the macbook I get the same problem. Apple logo, progressbar til 50% and than a light grey screen before going dark. Even when I try recovery (option + CMD + R)
    Please, help is very appericiated!
  2. BlueLineSwinger
    BlueLineSwinger Gawd
    683
    Dec 1, 2011
    Sounds similar to what happened with my MBP when the SATA controller failed.
    Does the MBP boot OK if you connect the drive to a USB-SATA adapter?
    Have you tried running hardware diagnostics?
    May also want to take it to an Apple store if you have one nearby. Not much they (or anyone else for that matter) can do for a system that old, but they should be able to make a diagnosis.
  3. dbwillis
    dbwillis [H]ardness Supreme
    7,680
    Jul 9, 2002
    cant you do the internet recovery thing to get the OS reinstalled?
    B00nie likes this.
  4. Shoganai
    Shoganai Limp Gawd
    396
    Dec 5, 2018
    pendragon1 likes this.
  5. pendragon1
    pendragon1 [H]ardForum Junkie
    14,594
    Oct 7, 2000
    that^^ its a well known problem and also try making an install usb to install from using your imac.
    if the firmware isnt updated it will keep getting the old os from the servers.
  6. dbwillis
    7,680
    Jul 9, 2002
    Yeh, but then upgrade from the store?
  7. pendragon1
    14,594
    Oct 7, 2000
    yeah that should work too, maybe.
    also op, i think its just command+r to get to the recovery mode. if you get there make sure to reformat the drive to get rid of the imac stuff.
  8. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    When I plug an ssd via usb/sata and press the option-key on boot I can select that disk as startupdisk. After that it seems like it boots but at arround 50% again the lightgrey screen before its poweroff.
    I have done a detailed hardware diagnostic. No problems where found.
    Thank you for the pointers
  9. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    After selecting the Option+CMD+R keys and selecting the wifi-network I get the globe with countdown.
    After that I get the Apple logo with progressbar,
    Arround 50% I get a black screen with blue vertical lines.
    Thank you
  10. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    When I try to install from an USB I get the Apple logo and the spinning donut below. After a while I get the cirkel with stripe. My empty Mac OS Extended (Journaled) formated ssd doesn't show. Not via Sata or usb/sata.
    Thank you for helping!
  11. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    I have an installation USB for OSX Lion and El Capitan.
    I formated my ssd (Mac OS Extended (Journaled) to delete all the Imacstuf After pressing control+R the recovery starts (spinning globe).
    I get the Apple logo with the spinning donut below. After a while the screen turns black and after light grey again. I hear that the fans are working very hard.
  12. B00nie
    B00nie [H]ardness Supreme
    8,039
    Nov 1, 2012
    If you end up taking the macbook to service do not use Apple service unless you want to pay a grand extra - they will swap your motherboard without even looking. Contact Rossmangroup in N.Y. if youre in US. https://rossmanngroup.com/
  13. B00nie
    8,039
    Nov 1, 2012
    Keep in mind that the internet recovery takes dozens of minutes depending on your network speed.
    If you can get the MBP to boot and you have the old drive left, you can boot from it using USB and then install to the new disk.
  14. Mazzspeed
    Mazzspeed 2[H]4U
    2,052
    Dec 27, 2017
    This is a GPU issue, the BGA soldering has failed. If you have a bootable OS, try holding down shift at boot to boot into safe mode and see what happens.
    I've fixed this before by reflowing the solder joints, not the most ideal solution, but most of the time it works - For how long is anyone's guess.
  15. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    I tryed to do an internetrecovery but after waiting for 3 houres I still got a light grey screen. When trying to install via the USB I first get the apple logo with a spinning donut below before it jumps to light grey screen.
  16. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    I tried it and got this result:
    I got the apple logo, folder with questionmark and cirkel with line true it. These were constanly changing. After releising the shift key it rebooted. Then I got the apple logo with the spinning donut before turning to light grey again.
  17. Mazzspeed
    Mazzspeed 2[H]4U
    2,052
    Dec 27, 2017
    You have GPU issues. See if you can find a repairer that can repair the problem. As soon as the OS switches to the GPU as opposed to the iGPU, that's when it's crashing and going white screen. Not uncommon on the 2011 MacBook and iMac's.
  18. Shoganai
    Shoganai Limp Gawd
    396
    Dec 5, 2018
    What he's describing in the first part is most likely a failing drive or a bad SATA cable. He needs to get it diagnosed as it sounds like there may be multiple issues here.
  19. Mazzspeed
    Mazzspeed 2[H]4U
    2,052
    Dec 27, 2017
    I've come across the cable issue before, when the cable fails the replacement HDD is usually not recognized at all, but for some obscure reason the old HDD is. What the OP is describing with booting to white screens and lines on the screen is definitely a GPU BGA solder issue.
    If you suspect the cable you chuck the HDD into a dock and try to boot from USB. If it boots from USB fine than the cable is at fault.
    Shoganai likes this.
  20. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    I switched the entire motherboard with anonther macbook same model and everyting works fine. Now I switched it back and must look more in dept what the problem exactelly is. I could buy another motherboard to make it easy but apple doesn't sell them anymore and they are to expensive.
  21. B00nie
    8,039
    Nov 1, 2012
    Where do you live? There are independent Mac services like the Rossman group where they can replace faulty cables and components for a fraction of the cost of Apple services. They fix machines Apple refuses to touch.
  22. StefanPeeters
    115
    Oct 7, 2013
    Hi,
    I live in Belgium. I went to an Apple store and apparently the macbook pro 2011 is a machine the refuse to touch because the are not supported anymore.
  23. Mazzspeed
    Mazzspeed 2[H]4U
    2,052
    Dec 27, 2017
    No, they class them as vintage! How good are Apple!
    Any reputable third party repairer should be able to at least reflow the GPU to get this machine back up and running.
  24. StefanPeeters
    115
    Oct 7, 2013
    Now I try to boot via a linux live cd (Fedora 24, tried also other versions and distros). I try to get some more information about what prevents me to boot mac os normal. I constantly get the message (Disabling IRQ #17) what prevents me from booting the linux live cd?
    Does anyone can help me what to do?
    Thanks
  25. B00nie
    8,039
    Nov 1, 2012
    I would try to boot OSX from USB instead of linux. Macbooks are not so simple to boot on linux IIRC.
  26. StefanPeeters
    115
    Oct 7, 2013
    I already did that but without result. When I press the option key when booting I can select the osx drive but after that I get the light grey screen.
    Tips are welcome
  27. B00nie
    8,039
    Nov 1, 2012
    This bug should be fixed in linux kernels 3.16 and upwards. Why are you using an ancient 2016 version? Current kernels run at 5.0
  28. Mazzspeed
    Mazzspeed 2[H]4U
    2,052
    Dec 27, 2017
    It's the GPU, take the device to any repairer worth a pinch of salt and they'll tell you the same thing. It was 'very' common on 2011 MacBooks, I've repaired a few myself.
    B00nie likes this.
