Hello all,
After plugging in a fire-wire cable into my new macbook pro the laptop shut down immediately. Probably was a fault firewire cable and caused a short.
So now the problem is the battery seems not to be working, the laptop boots up fine and runs while the power adapter plugged in, however as soon as i pull out the power cable it shuts off right away. The icon on the menu bar says "not charging" however the system profiler says the battery is good and is at 70%.
I have tried the SMC/PRAM resets with no luck. It is still under warranty, do you think apple would fix it? Probably going to take it to the store this weekend. Also any other ideas of how to fix this?
