Adding risers tall enough to clear the ODD may not give the PCIe card enough headroom. That has yet to be determined.Why would putting the optical under the mobo take away the pcie? The optical will fit between the riser screws. You might need taller risers but I don't see how that would stop a pcie.
Here are just some superficial renderings of two smaller versions of the already tiny M3A2. Internal design has not been fully developed. That will take more time.
Ultra-mini: 208mm x 208mm x 90mm; 3.9 liters
Mini: 325mm x 238mm x 90mm; 6.96 liters
- picoPSU, 1-2 x 2.5" SSDs, low-profile GPU
Standard: 325mm x 320mm x 90mm; 9.36 liters
- 1U or TFX PSU (under review), full-sized GPU (9" max length)
- specs previously stated
What do you think of that tiny little thing?
Haha, great! Would you be able to wait until end of May?I want that tiny little thing like RIGHT NOW. That is almost the same as what I was trying to figure out in those PM's, except I don't need the optical drive (wouldn't it block the fan anyways?).
Yes, it is. Interesting card!Is the case wide enough to use the zotac gtx 650 low profile?
Why not make the case 1 or 2 mm higher?
However, I can still make sheet aluminum cases of varying size on the fly.
wow. this is getting better and better! what is the height without the ODD and cpu heatsink clearence?And here you go, omit the ODD and all is right with the world, haha.
**Also note that I've sourced difference USB3.0 ports that are further apart, just haven't received them yet to create an accurate model.**
No, not really any room for 3.5" drives. Definitely not two of them.would there be any option to put 2x 3.5 hard drives into the ultra mini? without any graphics card.
I could use that as a home file server.
Sheet aluminum is much cheaper. I still make cases out of aluminum sheet, just not this one.If you use 1.5mm sheet aluminum cases, does it increase things like CPU heatsink clearance? Is it cheaper to use sheet aluminum? I'd really like 70mm CPU heatsink clearance for a 45mm heatsink and a 25mm thick 120mm fan.
You added 5mm to one of the original deminsions, is that width? Would you still need that extra 5mm with sheet aluminum construction?
Same as the original M3A2, 69mm at this point.wow. this is getting better and better! what is the height without the ODD and cpu heatsink clearence?
I do appreciate all the input! I'll look into that down the road.Wow now 3 versions after I ranted about going smaller, awesome lol.
Yes! Perfection at last should I say? =D. This is exactly where I've been seeing components land, in terms of size-conscious design, those 3 separate and unique sizes! The Ultra-Mini being a common mod you'd see around hehe, with a pico-PSU and pretty modest, LP card. The Standard, well it's great, you can fit the most powerful stuff, without having to go into the overrated water-cool-everything hype lol. The mini is the one that doesn't get a lot of love, and is long overdue! TFX please, a short, non-LP card, and with plenty of oomph for driving games at 1080p. TFX is ideal if for no other reason other than Seasonic making that Gold part. Seasonic #1 in quality and noise. Myself, noise is the #2 thing after size I take into account. Well, there has been love from manufacturers in this mini form factor, but it's been misplaced IMO, SFX when it can be TFX, Full Size ODD ew!, 3.5's when you should commit to 2.5 at certain sizes! etc.
The mini and ultra-mini, I would buy, without ODD space hehe. If Steam won't make a steam box, they should promote this as a DIY build or something lol.
Thank you! Lots still needs to be detailed out and designed, but the rough design is there.The Ultra-Mini is perfect!! Looking forward to more details (internal layout etc) on that one.
I don't think that's correct, the gtx 650 lp is a dual slot card, looks like the ultra mini is single slot only?
You don't need the second slot its just the vga port and you can disconnect the cable. However the cooler on the card takes up a second slot like a few other low profile cards so i wish their was more room.
I have to agree. Making the case a little wider is a small concession to make and allows for a little flexibility. Low profile cards are uncommon in general, so the ability to fit a dual slot version would be nice. That front panel USB connector might also create issues in the narrower design.
And about the optical drive. You could, if you really wanted to, just mount it above the board and use a low-profile CPU cooler. Noctua and Scythe make coolers that should easily fit in that space, and it's not like you're going to be putting in a very high power CPU anyway. A smaller vent, pushed toward the back, would still allow for fresh air to come in without being blocked by the drive. Space for 2.5" drives might be a problem though.
When it comes to low profile cards, is there any reason to get anything but a Radeon 7750? AFAIK they're all single slot. I guess having dual slots, or at least the width of dual slots, future proofs the case. But I see no point in the current market.
The zotac 650 is dual slot, I think that's a little better than a 7750. I have the 7750, it's actually pretty good, but it does struggle with heat. This case should have much better circulation than mine, but it's still hard for that tiny cooler to keep up.
The 650 is faster and their are 7750s with dual slot coolers.
Yeah, space for the dual slot cooler on a LP card would be the best bet IMO.
I agree totally. I won't be making the Ultra-mini unless someone requests one until after M3A2 Betas are out. But I just wanted to throw the rough renderings up for fun.This is just my opinion, but I think you should focus on something, particularly the 1st case layout. For the other's there are already similar cases out there in habey, Wesena, Streacom, while the first layout only exists in complete systems, which customers can't get w/o buying a prebuilt system. Again, just my opinion.
Not sure. Probably nothing beyond the top 120mm fan. Not really a whole lot of room in there without cutting vents in the front panel.EDIT. CMadki4, what case fan support will the ultra mini have? Obviously the 120mm on top..... will there be anything else?
CMadki4, if you're going to widen the Ultra-mini then it's probably worth putting a second slot for a dual slot GPU card. Just for future proofing, if nothing else.
There were a couple GTS450s made by Palit and Sparkle that had dual-slot low profile brackets, but I'm not aware of any cards recently. Might be worth it just for future-proofing, as ellroy said, or for mini-DTX support.
^^ but I don't think thin ITX is designed with a PCI-E slot in mind, there may even be power restrictions in terms of the CPU. So.. that really isn't for this case. That could be served with something with no room for a PCI-E slot, like an Antec ISK100, and similar offerings, not really the target for these cases I'd say, for something with that level of restriction, I'd go with an Intel NUC, doesn't get smaller than that.
Diverge, while I agree that there are similar cases to the ultra-mini out there, they all have reasonable flaws, including poor ventilation, poor HSF support etc. This case overcomes those short-comings.
