m2ne bios crash
R
ring.of.steel
Guest
hi, just recently set up my new file server this morning. my brother has been running the same config for about 7 months with no probs as his workstation.
spcs are:
asus m2ne
512 cheapo shitty ddr2
ati x300
thermaltake 420w psu
using 40gb for os, not installed other drives yet
so i enter the bios to select boot from cd and it keeps crashing in the bios, sometimes only parts of the screen appear. this is really pissing me off.
any ideas what the problem might be?
Make sure your BIOS is updated to the latest. I assume you are getting past the POST, so you will want to try swapping out your RAM if you can just to test.
Just starting swapping out all peripheral hardware to try to narrow down the problem. I have a M2NE that has worked pretty flawlessly (it seems no mobo is perfect).
Since you describe your RAM as "shitty" I would say that is suspect number one.
Best of luck.
swapped out ram, same problem. could this be a symptom of chipset overheating, i got it to boot from cd then it crashed...
thanks
