M.B will Turn off by it self
mir
I have a Giga Byte GA-P35C-DS3R. Which won't stay power up more then 35 sec.
If it is a booting from Cold it may stay Power up for may be for 1 min at the most.
Now if it is warm boot (like I am keep trying to re boot) it may stay up more then 15 sec.
Some time it will Pass POST some time it wont. It can Turn off while I am in Bios too.
I have tried with only
Video Card and one Memory Card with CPU. Same result.
PC Speaker usally do play Normal Finish POST beep.
About 3 weeks ago built in NIC would lose the connection from Network. It would be like it can't an IP address. Even if I assign a Static it would act like it does not have plug into Proper Network Segment. If I do reboot; MB will not past POST. I usally have to Turn off the P.S. for few seconds and then it will work.
I went a ahead disable the built in Nic and install my good ol 3Com 3C905TX Nic and that works.
From couple of days it wont past the POST. I thought my P.S. went south so I bought a new one (Corsair 400 CX). Same results.
I dont even know what is the Warrantty on the MB.
Hardware I have
CPU: Intel Xeon 3100
MEM : 4 (1 Gig) DDR2 OCZ
Video : 8800 GTS 640 Meg
Hard : 2 WD 2 Seagate
MB is not Over Clock or Never was. Every thing is Stock settings.
Sounds like a heat issue are you sure the CPU cooler is solidly in place? What about the northbridge cooler? I'm not sure if that board uses pins or screws to hold it in place, but I'd double check to make sure all your heatsinks aren't loose.
That is what I thought.
Stock North and South Bridge have Fan less Heat Sink.
CPU have Stock Intel CPU cooler FAN appears to be
Attached firmly
DID you remove the plastic Film form the Heatsink to the CPU =D
My friend did that once left the Plastic film on for the CPU cooler hahaha
I would take the cpu heatsink off and reseat it making sure the pushpins go all the way through. This probably involves taking the motherboard out of the case anyway.
