M.2 WiFi - simple or complicated?
I've got an AM4 ITX mobo that I'd like to add WiFi to, and my only PCIe slot is used by my GPU. The board, however, does have M.2.
I know that storage is the "big thing" for M.2, and I also know that buying storage for a given board can be a bit more involved than just buying any old drive. Is M.2 WiFi the same? I only seem to see Intel M.2 WiFi cards, are they the only game in town? Will one even work on a desktop mobo or are they strictly laptop territory?
Tried this recently. The M.2 wifi card didn't physically fit in the slot. Maybe I missed something, didn't dig in too deep. For reference it was an Intel 7260 card.
Also it was the Biostar itx board that I had too. I'm assuming that's what you're trying this with. I too wanted to keep the pcie 16x slot open. So it didn't work the simple way for me, but maybe there's a way to do it.
Why bother? Graphics cards don’t use more than 4x or 8x at best, so no need to worry
They have an itx board. So only one physical 16x slot. Doesn't want to use the slot for a WiFi card, wants to leave it open for a GPU.
I believe those little wifi cards you see on motherboards utilize the mini-pcie standard. It is keyed differently and provides x1 bandwidth. You could probably find an adapter off ebay, but your mileage may vary.
You can turn those little mini-pcie slots into a number of things actually. I've even seen a 4 port sata raid card out of one of them. (Probably not the best idea!)
Not sure if there are any quality USB solutions for your situation. If you had the room, you can also buy m.2 -> pcie 3.0x4 riser ribbon cables. If you had a 3rd expansion slot you could use a full length wifi card that way as well.
Unfortunately, when they created the m.2 socket specs they allowed for different keying options. Most motherboards are designed with sockets for keys B and M which are used in ssds,. But Intel designed their wifi cards using the E key. If you look at a close up picture of the Intel 9560 you will see a single notch near the middle of the card and the E marking. If you could see into the m.2 socket on your motherboard you would probably see 2 notches nearer the outer edges of the socket, the B and M keys. If you do a web search you can probably find pictures of them. So you can't add wifi that way unless your motherboard specs specifically say you have an E keyed m.2 socket. Even if you could its a hassle because you'll need to run two tiny antenna leads from the card to some external location on you case where you would mount the antenna connectors, and then add two antennas. So the costs and hassle add up compared to just getting a usb wifi adapter.
Thanks for all the replies.
I've got a little USB Wi-Fi dongle, but I hate carrying that thing around. It's tiny and I lose it on the regular.
I'm working with a Fractal Design Node 202, so I don't have the third PCI slot to run a regular card on an extension. However, I'm not averse to modding the case for antennas, and the M.2 slot on my mobo is on the back side, so after a finicky install it wouldn't be too much of a pain.
I'll investigate the keying adapter idea; it seems like that may be my only option.
For instance, something like this:
This is a less fun idea but many ITX mobos come with built in WiFI. After the cost of adapters and a m.2 pcie wireless card \ antennas, you are probably at about the same cost as just buying a mobo with WiFi and selling your current board.
I haven't ruled that out, and I'll see how the costs shake out once I've come to a workable solution. The thing about that is that in order to snag a Wi-Fi capable board in the same price range, I'd need to downgrade to a B350 chipset. That's honestly a pretty minor thing that I likely wouldn't notice, but it also includes the hassle of selling my old board... starts making that USB dongle not look so bad, y'know? XD
Maybe stuff the usb dongle inside the case somewhere connecting to usb headers? Probably still need to mod something to get an external antenna, because I don't think it'll work that well from inside the case though :)
I had that notion too, and may do some testing to see if it's got a signal worth a rat that way.
This PC is a travel PC, in a Node 202 so it can pack flat into my luggage when I have to go spend a week in a hotel by myself. The Wifi is a necessity for most hotels, and strong WiFi is a solid bonus... a little dongle antenna hidden inside the case may not fare too well. =)
Definitely not that particular one since its designed to convert a mini pcie socket to an m.2 A key socket. He needs an adapter that converts an m.2 M key socket to an m.2 E key socket. If I were him I'd just figure out how much I want to spend and get the largest fastest usb adapter. Something bigger than the little one he misplaces.
OK if the m.2 socket is keyed for both B and M he could use this adapter
https://www.aliexpress.com/item/NGF...mini-PCIe-SATA-SSD-interface/32618748503.html
to get him up to mini pcie and then use a mini pcie wifi adapter like the Intel 3945 or 5300, and then just add the wiring and antenna kit.
This has certainly been educational for me since I thought all m.2 devices were the same and never knew what a B or M or E key was.
If you provide the board model number the manual will state what it takes. I've used m.2 wifi card in several boards but vaguely i think most itx boards I have only have m.2 for ssd.
