Pinnocchio
- Feb 5, 2010
I currently have a setup using an Asus Workstation board with an IBM M1015 and 8 x Seagate 2TB drives in Raid 6...running Fedora 19 the drives are seen as JBOD and i'm using Linux's Kernel Raid setup...system works fine without problems and gives me about 11TB usable storage.
I want to increase the setup and while I was originally thinking of buying a DS380 chassis and doing a new build I've now decided to instead get a LSI 9201-16i and use 11 or 12 Seagate 3TB drives in RAID6, this should give me 24-27TB usable which I can't see me outgrowing for 3+ years. Part of the reason for the change of mind about the DS380 is that I already have a Coolermaster Tower case with 3 x Supermicro SATA HotSwap Chassis with the cooling fans....drives never get toasty and it's all one self contained unit with space for 15 drives cooled.
Reading around the LSI 9201-16i would seem the obvious choice but I haven't seen anywhere that it supports JBOD setups which I would need to be able to configure the Linux RAID....I have a fallback option of the Intel Expander Card but don't want to give up another PCIe slot if I can avoid it as I only have one spare in that machine.
The plan is to install the new 9201-16i and the drives temporarily outside the chassis on the floor, configure the RAID6 array (empty so should be a lot quicker), then do the data copy from the existing array. Once I'm happy that everything is OK remove the existing 2TB drives and put aside for 4-6 weeks as backup....remove existing M1015 and put the new 3TB drives into the Supermicro Chassis Slots....power up and cross fingers.
Are there any other cards I should consider and can anyone see any problems with the plan?
Thanks
Thanks
